Maybe with spacers and some portingOh WOW! Very cool part. Do you think that’s 600 hp capable?
Came from my buddy who worked for Chrysler. Raced a 62 wagon with the original 383/343 hp , this is the original setup off his car
Nice! but I don't think it's capable of feeding 600 hp.Oh WOW! Very cool part. Do you think that’s 600 hp capable?
It definitely won't happen if I don't tryNice! but I don't think it's capable of feeding 600 hp.
I wouldn't touch that manifold.It definitely won't happen if I don't try
Will a Victor with a 950 carb workIt's going to need a single plane or tunnel ram to reach 600 hp.
I have the 5186, that's what I threw in the dishwasher in the what are you doing to your car today thread. I gotta bead blast it.I think there is a slight problem with your selection of parts here. Your building a big block 400, correct? Then the only dual quad intake I know Edelbrock makes currently is for the 440. Unless you have an older cross ram or OEM intake?
Very cool !I have the 5186, that's what I threw in the dishwasher in the what are you doing to your car today thread. I gotta bead blast it.
[/URL]
[/URL]
I was thinking the Mopar Muscle Magazines of February and March 2012 would have more information. Alas no. They have somewhat longer write-ups on the 361, 383 & 400 engines used in the contest but not much more detailed information. Some of the engines were pulled to 8,000 rpm......some survived and some did not. One engine broke so badly you could look into the exhaust port on the cylinder head and see the lifter valley, camshaft and lifters! The exhaust valve head was stuck inside the cylinder wall in the water jacket between the cylinders.What a bummer they did t detail an iota of the engine.
All they said was parts used, IE Edelbrock intake and heads.
Not really sure what's available now. I put my 470" together a number of years ago and I used a Manley 6.760 rod w/BBM big end and .990 pin. The piston is from Diamond but I believe they considered it a semi-custom deal. Not really a custom piston at that time. Worked out great!ly rods will not work in a low deck with out special diamond pistons. aj
If an ly rod is bushed for .990 pins or use aftermarket rods with .990 pins, then any piston brand 1.485 piston & that would be on .045 down in the hole.ly rods will not work in a low deck with out special diamond pistons. aj
