WAYNE0
I took it all apart & reinstalled it. Also i took out the bolts that bolt the clutch to the flywheel. I could move the disk easy. I dont know if it was a good idea but i put thin washers between the clutch & flywheel. Now it works like its suppose to. All is good. Now the only issue is that the pedal has to be pushed to the floor. I even adjusted it more to where the bearing is sitting on the fingers. I can still move the bearing with my fingers but not much. Not sure how to fix that problem. Its as if the clutch rod isnt long enough & it doesnt have enough throw. Maybe i can screw a 2x4 to the pedal lol I wanted to test drive it up & down the drive way but i noticed a vibration. I walked out of the garage & found a u joint cap. wow
