- Joined
- Dec 31, 2005
- Messages
- 6,897
- Reaction score
- 4,316
Are you talking to yourself on a public forum again?Time to check your diaper. And then is a nap.
DAMN THAT THING.
I seem to remember that "art of war" indecent.. oh, never mind..Right, you don’t know. Stay in your lane.
Does that cover 9 identities or just one? Can you get like a license agreement for bulk ID's?Go "Gold" and help support the site. Easy to do, then you get the Large inbox.
Going to need a few IP's as well.LOL, yes moron, I’m yellow rose. And I have NINE other logins ready to go when snowflakes like you get butthurt.
Anyway, I have 10..
Random Name Generator — Easy Random Name PickerI wonder if he has a program that generates random aliases so he doesn't have to sit there for days coming up with new handles.
Anyway, I have 10..
Another Triggering.......You guys just have to learn to be nice!!!! Like ME. Lol now take your 318 azz junk and shove it up your butt.
Umm.....I'm still on my first......I don't need sock puppets because I don't get triggered.
Do you and your 9 identities ever talk to each other like one big echo chamber? In Psychiatric circles that's called that Schizophrenia............
Maybe its just the other identities that you live in your head that are getting Triggered every time some one mentions 220+ cfm and 302 heads in the same sentence?
Valves that were designed for loads of 80/220 lbs seat/open. Makes since...I always put $3 valves in my high performance/max effort builds.
Hate to break it to you, but this 318 won't be any valve killer.. you obviously missed that, but I guess it's all about having more sour grapes to share around right?Valves that were designed for loads of 80/220 lbs seat/open. Makes since...
I've seen more #163 casting heads on 318s than any other. Don't look like very good ones either.I would use the most common 318 casting on a 318 build in this particular situation.. Mainly because that's what it had when it rolled off the production line.
and that's where the project, like this thread, jumped the shark.I've seen more #163 casting heads on 318s than any other. Don't look like very good ones either.
I ain't the expert but if you restrict the parameters of the build to "heads that came stock at some point on a 318 LA during the years it was produced" /
Meaning NO 340 heads, NO 360 heads, NO aftermarket heads allowed/ I like the looks of the 302s better than the 163s ... I have heard the praises of (I think they are 920s(?) From the late 60s/, though I haven't seen a set of them in like, forever.... and can't remember what it's chambers looked like. And as low buck as can be....
meaning basic home porting allowed, and standard "down the street" "around the corner" small town America type, machine shop-grade work, would be allowed to finish them up ... No shady dell, no Dick Landy or Herb McCandless or Petty hi tech, high dollar stuff allowed... Though, a before (stone stock) and after flow bench comparison would be welcome.... Measuring head flow, doesn't change parameters in and of itself.
But, it would be nice to know if that small town, typical gearhead/car enthusiast grade of porting and machine work, actually helps or hurts performance. The original parameters were to get the power from STOCK parts, right?
So, let's see a fresh, genuinely stock engine, thoroughly blueprinted, tuned as best as can be tuned (hey, things like stock advance curves were all over the map over the years and several versions of the BBD etc) and let her rip.
Cop motor heads, cam, etc THAT WERE USED IN A 318 from the factory during it's run, are fair game.
well, if you extrapolate the phrasing and pejorative words used, supplant that with some of the time frames given as examples-- I did all that **** in the 80's-- and then add in the types of insults used and weigh that against the grammar and spelling consistencies...I wonder how old some of these guys are, joking about "old men" and saying everyone is "triggered"
Looks like they are just going to use the 360 valves now, maybe some of those posts won't be getting moved after all.and that's where the project, like this thread, jumped the shark.
UTG and suspects immediately moved the goal posts after initial statements and went right to offset grinding the crank, regrinding the cam, pro porting the heads, thousand dollar pistons, and aftermarket valves.
let's see what an honest 318 will do. basic rebore and machine work, blue printed with factory parts.
I'd bet that the result would surprise quite a few people in regards to overall cost to power made.
but this whole charade? entertainment value for clicks.
Meanwhile having an emotional response yourself. Why did you start the thread and share the yt video. You must have been really excited about it ...or is it just more of the same old chest pounding..over someone elses accomplishments none the less. Reality is... they be best for a 273 cid in the 1.78/1.5 ported form.. Best head for it actually. They be okay for a 318 in the same form ..1.78/1.50 ported.. but not for max power, that's when you use a bigger port.I always find it interesting when people have an emotional response to any appeal to logic.
That's some ugly stuff you got going on there. lolThis is really the intake manifold they need to used on their 302 headed 318 final build using mopar parts.
These made for mopar dual plane aluminum intake manifolds even have Chrysler part numbers on them.
Proper runner sizes to match up to the 318 cylinder heads, for the smooth port flow and port speed.
Definitely going to need more carburation than the stock 2 bbl that was original In 1969.
More like this mopar larger cfm 2 bbl carb to make the power.
