Too quiet here ....
I've never been there, so I've never had one. Sounds good, though!
This might be controversial:
  • Parallel hybrid system pairs an efficient 1.6L engine with an electric motor
  • Improved, second-generation 6-speed dual-clutch automatic transmission shifts gears quickly for seamless acceleration
  • Regenerative braking technology
  • EPA-estimated 49-53 MPG combined offers class-leading efficiency
  • 479-588-mile projected driving range
Is that even possible? I personally don't think it is is that controversial enough for you?
That's an awesome gas pump man and I take that horse stuck up in the left corner over there my friend ( old drummer) his Dad (they're both gone unfortunately) had one like that in his diesel repair shop it could actually trolley across the building, and back and forth, with the remote hanging down from it! the thing was kick ***
Gen 3 hemis with 8 3/4 rears with green bearings
Here's all I know about green bearings... my friend has a mint condition numbers matching 71 340 4spd Cuda, I guess you have to have something done to the housing is for the lock rings by a machine shop or something? Well they didn't cut the groove right for the lock ring or whatever, or the external snap ring, he turned a corner the damn axle shaft popped out!
I have used that gantry for a million…..ok 20…..things. It is now priceless. I’m too old to lift everything now. Maybe just wiser, but regardless, it’s good for 1300lbs.
