Help my thermoquad lost its balls
wreckbuilder
Tenessee
Rebuilding a thermoquad and had the top section soaking in Simple Green. When I took it out there was these two balls in the bottom of the pan. Does anybody have a idea where they might have came from?
Also I noticed the metering rods are different lengths.
2 balls? Hummm, well, there is supposed to be one under the primary squirters so the fuel doesn’t get sucked out of the pump shot nozzles.
Two and three step rods? Broken rod?
I can’t really see on the phone.
Just a wild starter, what is it off of, and do you have a service manual. You can download many over at MyMopar.com
And........
The check for the pump squirter should be a long needle like a needle and seat. Maybe some corrosion, and the balls are supposed to be plugging dead end passages?
The rods both have two steps The small diameter is longer on one rod. Didn't know if it was broken off or just a different length.
It's either been broken off or they are different rods. They are supposed to be the same. Some models did have the pump squirter check ball but I couldn't tell you where a second one would go. Most kits include the brass pointed squirter check valve, so they will usually eliminate that check ball anyway.
Maybe it had two balls in the squirter? I didn't find a brass pointed check.
The longer rod, with the long tip, looks like it might be from an AFB carb. Maybe somebody was experimenting with jetting.
Not for nothing - but I’m no thermoquads expert but I do love them. I started out in the early 80’s working on them and learning to tune them with books like this one. Any book newer than will have the emissions bs. Even some of the older Motor or Peterson books had Info on them back then. Good pictures and breakdowns that even people who knew them learned something. You can find these books on eBay or old book resellers, yard sales and flee markets. Good luck on your quest to figure out what to do with the extra ball.
Lol!
Balls and metering rod. Yep, those 2 things go together.
