Turning back the clock
The lines have more than enough wiggle to drop the K past the brake line. You can see a zip tie in the radiator support bolt hole holding the line in place on the K. I do not remember seeing any engine install / removal (NHRA or NASCAR) thru the bottom, back in those days or even now for that matter. Engines came out thru the top, with or without the transmission.
We started mimicking the factory install thru the bottom in the 90's to eliminate the scratches and install the engine, transmission, and exhaust manifolds / headers as a complete as possible. I don't think either was / is a high priority with either.
Yeah, I agree, installing the engine from the bottom is really a restoration procedure. Figure if the team had to take the engine out it would have been easiest to just pull it out from the top like normal so as to not have to mess with the suspension. Probably took 20 minutes at most with the motor plate. No way anyone is dropping the K frame in the pits at a race or even in the shop trying to make repairs for the next meet. I'd be willing to bet they even made the core support removable to facilitate that.
The two main reasons for me come from the bottom is because 1) I can with a lift and 2) header clearance. I'm not even sure it will work with larger headers though. It's worth a try since fighting with them can be a nightmare. Either way I'll be investing in some moving blankets for sure.
I looked at the brake lines yesterday. It's a little more complex to run them along the radiator support, more stuff in the way. I'm a little wary of it across the K frame though with street driving. If it was a dedicated race car then 100% it would go there. Also considered running it in the passenger compartment under the dash. Looking at thru-frame bulkhead fittings to ease the install.
I looked at it time and time again and the fuel line location makes sense. The 1/2" aluminum fuel line travels for the most part on the outside (like OEM) of the car and connects to 1/2" steel braided fuel line that stays out of the engine bay freeing up needed space but more importantly (IMO) away from engine / header heat. Where the steel braided line installs under the UCA, it cannot get crushed and is easily removable.
It makes sense, just not used to seeing it there. There are a couple existing spots in the frame rail one could pass a line through or higher up on the fender apron. Just getting it there through the outside bulkheads is a bit of challenge though so that's the hesitation. I'll figure it out one way or another, that's what it's all about.
Always interesting to see how the race teams did stuff though, provides a lot of inspiration and ideas to copy or expand on. They (presumably) did not street drive these cars so there was little to no need to accommodate things that could be damaged during regular street driving. Not having to compromise makes things easier for sure.
I'll step out now, thanks for playing along in your thread.
Thanks for the conversation.
getting ready for Carlisle 2023
Nice. Looking forward to seeing it in person.
please make sure you hunt me up too, Ill be there from Thursday to Sunday......and that goes for the rest of you, don't be shy, it is always nice to put a face with a name.
installing stickers like the giant GUMOUT and the event decals to mimic the way it looked at it's first outing....WinterNationals / Pomona 1975. Other than that, air up the tires, add fresh fuel, prime the oil pump and fire it up. After that , give it a fresh JAX Wax and its time to load the Flash.
I love this race car. it always brings me back to being 19 years old (late 74) and building my first Duster with two of my very best friends and mentors.
Just want to take a moment to say thank you to Denny for letting me drive The Flash! What a thrill to get up close and personal with a work of automotive art. You done 'ol Butch and Ma Mopar proud, kid.
Tuning for The Nats.
A step hotter on the ( cough / cough 16) spark plugs, adjusted the front carb float level (tad too high), reset the throttle / carb linkage and lastly, after a warm up reset the idle matching the amount of turns with the front and rear carbs.
The Hemi seems happier now and so am I
Loaded for 10 'o'clock pull out after loading the cooler with brats, condiments, and refreshments. I like to take care of my guests!
Best indoor show known to mankind. Spent all three days looking around and I'm sure I didn't see everything.
Even better than the Grand National Roadster Show at the Fairplex in Pomona?
Or the Detroit Autorama?
Different ball ‘o wax. I went to MCACN for the first time this year and it blew me away. Everything is super high level.
Never been to the traditional hot rod shows out west but I can guarantee that this show would not disappoint on any level.
'Ol Butch is alright, he'll take a picture with anyone.
Butch and the race car have impacted my Mopar hot rod life for the last 50 years. It is fun to be the fly on the wall seeing their reactions and hearing the stories when fans and fellow racers meet Butch. Never a dull moment....unless Butch takes a smoke break.
With great sadness, I announce the passing of my older brother, my partner on this Butch Leal / California Flash restoration and my Mopar mentor, John Laube. We will miss his humor and wit, I will miss walking in his footsteps. God speed Brother John.
