Bugman
with 65 amp alternator by green dot ce41Thank you so much! It's great information
oil pressure and temperature use grommet green dotpost 45 above green arrow ce34 clutch starter switch looks like yours is by passed
That is a heavy duty arrangement. Probably the '65 amp' alternator option, either with or without the heated back glass.coming off the amp gauge in the dash. There's a red and black wire that go through the firewall in a small grommet. The red goes looks like to a fusible link to the starter relay and the black I believe goes around to that big white connector on the engine
Mistake eye,s bad fuse link might go to cavity j instead of Z, both cavity take fuse links, not sure yet
Mattax is right, fuse link in place start relay good, One fuse link left cavity Z ignition switch feed. Is it there or plain wireJ1 12r ignition switch feed fuse link j1 18 gy/r cavity Z cavity j fuse link A1C 18DBL To starter relay
It has two ring terminals on the amp gauge, one red and one black. They look to be originalSee how many ring terminals are on each side of the ammeter.
On the battery side, A1D is the standard wiring connection from the bulkhead to the R terminal on the ammeter. It should have been removed (or cut and taped) when the optional wiring was installed. On the other ammeter terminal, the standard connection could have been left in place. In fact without it, I don't know how the power gets to the key switch.
It has no heated back glass but it does have the seat belt wiring stuff. It must have been bypassed or something because I can get the car started like it should. I'm just trying to get amp gauge in the dash to workThat is a heavy duty arrangement. Probably the '65 amp' alternator option, either with or without the heated back glass.
If you post photos it will make it easier to narrow down what is on the car.
The 60 and 65 amp alternators will be indicated on the tag if its still there.
Not many of these optioned cars documented. Mostly the ones with the heated back glass but even then not '75s.
Forum member Mark has one in Switzerland but IIRC its a '74. I reminded him to follow up so fairly recent thread.
As a wiring strategy it is pretty straightforward.
The complicated wiring is the seatbelt interlock. One answer would be to wire it so it is always ridden. Same way the switch on the fender temperarily overides it.
I thought that starting was an intermittent problem.It must have been bypassed or something because I can get the car started like it should.
Did not know that.I'm just trying to get amp gauge in the dash to work
They might have cut and taped the R6D.It has two ring terminals on the amp gauge, one red and one black. They look to be original
www.forabodiesonly.com
Not sure what the advantage of cutting it was thought to be.
Leaving it connected provides a second path to the J1.
Here's some pics of Mark's '74 with the optional wiring and heated back glass. We see they left standard wires in place on the engine compartment side.
[/URL][/[/URL]
