Help me find the umph in my 360
Al at ALS499 on ebay has had those cam chain oil drippers in the past, oil slinger on the crank too. Zumbrota MN.
Can sign into your ebay, look him up and hit the Contact seller button.
Jegs lists it as 5 days.... jegs sucks balls though.. never know
[/URL]
I will never order from them ever. My last order they threw all my Stuff I ordered into a big box with no packaging bubble wrap or anything. It was so bad my yukon dura grip had bounced around so much in the box that it was sticking out of its box. I was super pissed. Summit has always been fantastic. Also with that howards cam with that 508 lift will my stock rockers be ok with that high of lift?
Yeah.. i ordered $3500 in small block ford parts and all that showed up was assembly lube.... that was my last time
I had heard Howard's is a decent cam company.
I saved some money ordering a Howard's cam and lifters from Jeg's instead of Summit recently. Be sure to check both for pricing if you start down that road. Er, or not, based on more recent posts. LOL.
I just realized that is the same exact cam in your post that I have for my engine. Not installed yet. They had a long lead date to get it too, in the end it was here in 3 weeks drop shipped from Howard's. No fuss no muss.
Just ordered the howards camshaft. They had one sitting on their shelf. Now ordering everything else for replacing broken stuff. I went with a Mancini timing gear set also. Decided to go ahead and get a high flow water pump as well since everything is apart.
I heard Jegs got bought out a year or so ago?
"Jegs, the mail-order auto parts behemoth that has been firmly embedded in the American aftermarket scene since its formation in 1960, has been purchased by a private-equity firm. This is the first time the company has ever received private funding, according to a report from Dragzine, marking a stark departure from its family-owned status for the past 62 years."
Jegs, the Famous Auto Parts Catalog Company, Sold to Private Equity Firm
Any one have any videos of the Howard cam I bought. I can't find a video on what this cam sounds lIke.
Actually I recant my previous recommendation. Use this one instead.
That way, you can run the Comp 901 spring which is cheap and a drop in. Same basic cam with less lift. Call Howards directly. I bet they have it available quicker than what Summit says.
Here's one in a 340.
Private Equity Firm = Rape, pillage and make as much money as you can before filling bankruptcy.
If my memory serves me right the were .110 in the hole. And these are the speedmaster aluminum heads.
0.110" deck height? Not good. Any quench is in the basement of the outhouse. Slants are even worse. Building an eengine today, I would be looking for a zero deck or possibly -0.005 deck height. The - indicates the piston is proud or above the deck. You want for a street engine that will run to 6500RPM a clearance between the piston and cylinder head quench area of 0.035" to 0.040" with the head gasket compressed. This aids mixture motion in the combustion chamber which aids quick and efficient burn.
Mixture motion can be two types;
1: swirl. This is similar to the water swirling when you flush the toilet. 2 valve heads tend to have this but port shape can promote or inhibit this swirl. SBF ports tend to inhibit swirl as the flow wants to dump out close to the cylinder center.
2: tumble. 4 valve heads tend to tumble, which is OK at lower RPM but becomes ineffective as the RPM increases. What happens is swirl is cancelled by one valve's flow wanting to swirl clockwise and the other counter clockwise.
Too much swirl can be counterproductive also, but generally more is better.
IMHO you need pistons with a taller compression height.
According to David Vizard's 128 formula for LSA selection and assuming 2.02" intake valves, you need a cam with the LSA at 103°. Yup, might tend to a bit rough idle. I would be looking at more like 265° to 270° advertised duration and lift around 0.525".
In your initial post you say the carb is an Edelbrock 1905. This would be an AVS2 650CFM manual choke item, with annular discharge boosters in the primary side. In a subsequent post you state the carb is a 1405. This carb is a Performer 600 CFM manual choke with conventional boosters.
So which carb are you using? Either are good carbs, contrary to what one poster states. The base calibrations are different and not explained by 50 CFM difference. The Performer 600 is an older design set up for non oxygenated fuels, no ethanol. The calibration is for a 14.7:1 cruise AFR or a lambda of 1. The AVS2 are calibrated to work with the oxygenated pump fuels today. Because of the ethanol content they require a "richer" calibration as read on an AFR guage. This AFR should read about 14.1:1 to obtain a lambda of 1.
Choice of the optimal carburetor depends. With your stated Airgap manifold, the AVS2 with annular boosters is the better choice due to the annular boosters providing better fuel atomization to the manifold. The Airgaps do not have the heat in the runners that regular manifolds have, so more atomized fuel works better. Now a conventional manifold with a fair bit of heat transfer work well with conventional boosters, but may tend to vapourize the fuel more in the port. This causes the fuel volume to expand greatly, which causes a less dense air and fuel mixture reaching the cylinder.
Nothing wrong with Edelbrock or for that matter Rochester carbs. You are correct, just gotta learn to tune. Obviously you race using Holley carbs because jet changes are easy. To do that you have to catch the float bowl fuel when you remove the float bowls. On the Edelbrock/Carter you probably only need to loosen two covers to swing them out of the way to change metering rods, and no spilled fuel. If you need more extensive fueling tuning, remove the top cover to replace the jets. Again no fuel spilled. Just gotta learn to tune. Comparing a 650 CFM Edelbrock to a 650 CFM Holley should produce about the same power. Same for the 750 CFM models. I hear/read the Holleys flow slightly more air. On a race track the difference is probably noticeable but on the street, not likely. DP? Really? Again on a race track for throttle response, OK. But on a street driven vehicle they are harder on the fuel gauge.
The edelbrock I have does have the boost venturies in the back and i believe it is the performer edition. I bought it used. But I also have a 750 holley 1406 electrical choke and vacuum secondary coming also. I like holleys better. But I will have the edelbrock as a backup on the shelf.
