justinp61
- Joined
- May 15, 2009
- Messages
- 3,073
- Reaction score
- 4,063
I run T&D 1.7’s on my Indy heads. PRH ordered them for me.
The Indy 360-1 top end package comes with T+D rockers
5 grand for the whole 9 yards seems like a fair price to me, but that's me
I’ll have to check out their site sometime. I must have a bad link because mine has never been updated. Is that posted or stock, Indy intake, and T&D rockers for 5000.00.
210cc head with intake, gaskets, pushrods, head and rocker studs and rockers.I’ll have to check out their site sometime. I must have a bad link because mine has never been updated. Is that posted or stock, Indy intake, and T&D rockers for 5000.00.
Is this the updated pricing, the sheet I looked at was effective from 4/13/2023 and either HS or T+D rockers for 5 grand.
It's probably last year's catalog, I was looking at head packages last summer and it's what I already had on my phone.Is this the updated pricing, the sheet I looked at was effective from 4/13/2023 and either HS or T+D rockers for 5 grand.
Thanks I’ll check that out at the track tomorrow.
Let me know what you think. I've been side eyeing a set for the last year or so, I can't leave well enough alone I guess.
What would you charge to port a 360-1 if you were interested in porting them. Pm if you like.My thoughts on those heads is I probably wouldn’t get the 245 maxed out heads and I have two leakers on my shelf that I bought from my buddy. I have posts saved on my computer of lots of issues. My 360-1 heads are had ported and far from maxed out and have gone the same exact 5.98 as my Edelbrock heads and they aren’t maxed out. Their exhaust program doesn’t have to be as aggressive as it is especially if you go for fast airspeed like I do. They take too much material out.
This here below;Is this the updated pricing, the sheet I looked at was effective from 4/13/2023 and either HS or T+D rockers for 5 grand.
Will my current valve covers edelbrock RPM type, work on the indy cylinder heads?
Can you share which spacers I would have to purchase to make them work?I run spacers on all of my stuff and my mopar performance once worked on mine. A lot of these covers hit on the better manifolds (super Victor and Victor340) so I run 3/8 valve cover spacers on everything now.
At some point when you have time, could you please post a picture from the intake side, kind of like replicaracer43 did of his head, but showing the clearance you have on that setup between valve cover and intake. I need to order a pair of those but keep putting it off.As I’ve told guys before I love these spacers but they are not a bolt on. At least not for me. With the 1.6 rockers I run on about everything I had to grind for pushrod clearance so check this out. Also if you run the fan valve covers I had to slot the holes because those bolts came in at a funky angle especially on my Indy 360-1 heads. Not a hard job but a much easier job to check out on an engine stand.
I looked back in my gallery and I have a few pictures but nothing that is going to help you. At least on my Indy heads. And that combo won’t be back together till next year. I posted a few of my Edelbrock heads with themAt some point when you have time, could you please post a picture from the intake side, kind of like replicaracer43 did of his head, but showing the clearance you have on that setup between valve cover and intake. I need to order a pair of those but keep putting it off.
I’m at the track and internet sucks more than normal. Might have to wait till Monday. Remind me. Upload speed is 2.
Those pictures helped a bunch. I can see how tall it looks next to the intake with that spacer in place. Thanks, I appreciate it.Well
On in my alcohol post last week then o think I deleted my pictures.
