DallasMan2000
Just found this wiring diagram for the car.
As I attempted to elude in my post, taking random readings does you no help, and may just confuse us. Try to picture this:Just for grins, I took a reading with the key off from the battery to coil positive and got 2770 Ohms. My meter switches automatically. Don’t know if this means anything.
Yes. Situated just like the wiring diagram below it. The "key" is the key in the ballast ceramic. The "U" cutout at the bottomFrom the wiring diagram, it looks like the upper right pin of the ballast (with blue and brown wire both connected) has the brown wire going back to “key start” in the ignition and the blue wire goes directly to the positive side of the coil. Does this sound correct to you?
Crumple that up and use it to start a Bar-B
www.forabodiesonly.com
battery voltage at the connectors only indicates dead end, or no current flowing through resistance before the test point.This car has a 4 pole ballast and I get 12.5 volts at all 4 poles with the car in run position.
Suggests that no current was flowing through, and no voltage is available in run.Both the coil positive and negative get 0.632 volts with the key in run position.
Ok. This test seems a litle random but if the battery is also at 10.5 Volts with the key in Start, that is correct.I unplugged the top plug on the ballast and got 10.5 volts coming to the right side of the plug (brown and blue wire) with the car in start position.
With engine not running, that is correct.Pin 1 in the ECM plug gets 12.5 volts with the car in run position.
I agree with Bewey, it strongly suggests a break in the Igntion start circuit. In particular between the poiunt of measurement and the connector you measured 10.5 at with key in start.Positive side of the coil gets no voltage increase with the key in start position.
Coil works. Ignition works when provided power.Run a jumper wire from the battery positive directly to the coil positive and the car fired immediately.
See previous post.Here are the male and female ends of the firewall harness. Anyone see an issue here? Also, anyone know which sockets the “key on” and “key start” come through? I think we are looking for corrosion or something else that would cause a weak connection.
Those should be blank, its the wiper connector.If its not the run and start on this picture of the Bulkhead connector then something is not working as that is a lot of corrosion
His Bulkhead connector has the left two female pins missing. The right top looks distorted like heat compaired to all the other pins. The lower bottom looks damaged too.Those should be blank, its the wiper connector.
Wiper Motor Interchange List with part numbers/years/body styles...
1970dartcustom submitted a new Article: Wiper motor interchange list with part numbers/years/body styles... Part#/Stamp# Year-Yr Body Speed Remarks 2525629 1964-66 A VARIABLE 2525270 1964-65 B SINGLE 2580915 1967 B VARIABLE 2584975 1965 C VARIABLE 2586988 1966-67 C 2/3 SPEED 2587697 1968...www.forabodiesonly.com
