Hoosier Quick Time DOT Burnout Question
71GSSDemon
WI
So, due to other life problems I wasn't able to get the Demon to the track as planned this fall but watching cars run last night, there was no room to drive around the water for burnouts. With a shallow tread on the soft compound and wrinkle wall, should the water be avoided? My thoughts were about water being in the tread at the starting line. Is this a thing? Pic of tire attached.
I've never been to a track where you couldn't drive around the water box. I hope you are mistaken. Is this on a street night ?
It was street night. I couldn't see the area well enough maybe. Mentioned above it may not be an issue. Just me overthinking??
I would avoid the water with tread. The burn out area is usually wide enough for you to drive around the water area. Swing out past it. Back up and do a second gear burn/tire clean. I find those harder treaded tires get slippery if overheated. Depend on the compound. Good luck!
We ran the Mickey Thompson version of these 20 years ago. We just drove thru the water box and stopped and proceeded with a normal burnout like a slick. Basically once you see a little smoke roll out from the burnout. They worked well for us, but we used them on a 67 Plymouth Belvedere that was running 8.0-8.30s in the 1/8th mile.
those are treaded slicks , not hard rubber at all...jfyi
I ran a pair of these for several years and a lot of street miles on a 67 Satellite. I loved this tire on that car. I would drive it to the track, make a bunch of runs, then drive it home. I never went around the water. Like @MOPARMAGA said, there won't be water in the tread after the burnout.
