Never tried swamp water but ask the concession stand person for a diet water and see the puzzled look on their face.
OUCH that hurtsThe weather has hurt me bad this year drought when planting the non stop rain. Even 9 inches in one day. Yield should average 45 bushel an acre and I am as low as 10 per acre in the clay.
Scoot your butt over Mark I'm coming for meat pie.Nice and sunny but a cold wind but did a pile of shopping again.
No more room in the freezer believe me. Only problem now is my wife has been making meat pies all afternoon.
We'll have one tonight for supper and tomorrow as well but the rest I have no idea.
Have a great evening
Where's the marshmallows?
What did you do?
What did you do?
To hot ! But it was a big hit apparently you could see it a mile awayWhere's the marshmallows?
Sheesh CF. You sure have some stick with it. You must love farming. Woke up to snow here and rained ALL DAY. I'm glad to have an indoor job.Well not a good day farming. I got a few acres in and started hearing a bearing grind. Found out I had 2 bearings fail. One was fixed in less than an hour the other was on the chain shaft that pulls everything in the combine (feeder house) that one took 9 hours. I had to do a several hour run to get the bearings and also had to go to the tire shop as the truck had a flat when I went to use that and the tire needed replaced. I will back the combine out of the barn in the morning and try again.
Mid 40s again today here and some light rain this afternoon, last weeks' snow is pretty well all gone now, might see 50* on the weekend.Sheesh CF. You sure have some stick with it. You must love farming. Woke up to snow here and rained ALL DAY. I'm glad to have an indoor job.
You're welcome any time and that goes for everyoneScoot your butt over Mark I'm coming for meat pie.
Sounds great.
Should have stayed in bedWell not a good day farming. I got a few acres in and started hearing a bearing grind. Found out I had 2 bearings fail. One was fixed in less than an hour the other was on the chain shaft that pulls everything in the combine (feeder house) that one took 9 hours. I had to do a several hour run to get the bearings and also had to go to the tire shop as the truck had a flat when I went to use that and the tire needed replaced. I will back the combine out of the barn in the morning and try again.
Lucky you lolSunny and mid 60's today. Get to pour concrete today.
