FYI
the OP's cam installed at 103(split-overlap), looks like;
279intake/117.5comp/101Power/296Exhaust/73.5 overlap/Ica of 62.5
Whereas the 292/108 in at 106* looks like;
292 intake/108 Comp/104 Power/292 exhaust/76* overlap/Ica of 72
These two engines will have completely different personalities. and that's before you even look at the .050 numbers....................Jus saying.
Given two identical 360 engines, at the same 10.7 Scr :
the Comp cammed engine might pump 164psi, whereas the
292/108 cammed engine might pump 147psi. whereas the
292 in my 367HO, in at 104, pumped ~177psi, @11.3Scr
But OPs engine with open chamber heads is not likely to to be a 10.7 engine. Perhaps 9.5 at best, which would put the pressure closer to 153psi
BTW;
I ran that 292/108 in my 367/4speed/DD, for just under one year. I ran it from 100 installed to 108; in 4* increments. I tried really hard to love it. But it did not repay me. It hated 3.55s : top of First gear was 61mph, Second gear was 88mph, Third was 116. Cruising: 65 was a tic under 2900. So, I yanked it.
The next cam, with no other changes pumped 195psi. Now, that was really something! I was really impressed by the bottom end, but the top end was a lot softer than it had been with the 292. I retarded that cam, got 187psi, and the top end became acceptable.
Then I threw in the towel, got me an overdrive and 4.30 gears; and finally, all was well in the world; top of Second was 70/64 in First-over, and 65= 2700
I have never missed that 292 cam. Plus it sucked gas big time.
I was very sad when this little 270/110 cam dropped lobes.
IMO
Some people say cylinder pressure is not important. I say
That's like having a wife, who has no interest in sex.
In both cases, all the parts are there, but they ain't put together right, and neither is a keeper.
That's my opinion.
