coloradohill
I am looking to get away from the usual pcv valve system for the street.
My in progress build is a Indy headed 416 with a tunnel ram and two Holley 660 center squirters.
The carbs don’t have vacuum ports so I have been running one inch spacers with ports for the pcv with my current Edelbrock heads.
The valve covers for the Indy heads are setup for header ventilation.
Looks like a dual inlet catch can is a good solution. From what I’m reading, a baffled can is the way to go with a filter for the outlet air.
I’m looking for recommendations on this , cans to go with, advice on plumbing the system ect.
Looks to me like you just run lines from the valve covers to the can. Is this correct?
TIA
TIA
