I think i broke rear main bearing
illrad91
sacramento
I was bolting it in and I noticed it kept going and when I took it off it was cracked. What are my options idk even know how to replace or where to get this part or what the proper name is for this part
Those 2 bolts will let you remove the cap and a cap should be easy to get but I think that the block will have to be align honed and new bearings.
So I'm tucked? What if I jb weld it and rethread just so it could catch or should I leave that bolt off? Does that mean I can't start the motor because that's what I was gonna try to do next
I wouldn't use jb weld on a major engine component regardless.
BTW, it there a heli coil in the other hole. Was this engine apart before? That crack may have been like that from previous person. Not making sure the oil pump is flush before tightening can cause that
Idk I took it off to put the new oil catcher pump but I think i tightened it too much by accident man I'm not mechanically inclined for this guys please help I don't want to take that part off
I don't think that I would use a heli coil for any engine block repair.
The motor was rebuild from what the owner told me
I don't see any way around it
The OP said that he was told that the engine was rebuilt before he got it. Myself, I don't see any other way but to pull the engine and fix it right. I don't believe in patch work or doing things half as*ed.
I think I fixed it I rethreaded it and put a bigger bolt and it tightened down but I'm not gonna put too much force on it what do you guys think?
Why not. Done correctly the insert is stronger than the parent metal.
You need a new rear main cap which is a PITA to install.
I've never seen heli coils hold up when used in a stress area. I have a friend who had a block where the machine shop used heli coils in the cylinder head bolt holes, it never held a headgasket after that. The cap is a breeze to install, the problem is having the block align honed
