Anyone done a strong 400 build ?
The longer you wait, the more things cost, ask me how I know lol.
Fortunately I've got the 400 virgin block.it seems stroker kit prices have leveled out somewhat
, $ 2700 for a 512 stroker kit
$2500 for heads and intake
Probably $2000 in cam and gear
Machining, gaskets, oil pump etc
$2800
Equals 10k
Plus another 1k for things you forgot
Equals 11k
$2800
Equals 10k
Equals 11k
Add 30%+ on top of that because it happens with every build.... lol
$2800
Equals 10k
Equals 11k
Good carb, good fuel system, good exhaust, good converter, good tires, good transmission, good differential. Tied frame rails,
My $900 converter that I ordered a year ago turned into $1070 when it shipped, now I will be up to $1200 by the time I get it back. Would much rather have spent that money on a different converter from you know who.... lol
That sucks,
Yeah but you'd have to talk to him for 1.5 hours lol
$2800
Equals 10k
Equals 11k
The shop I work with builds Mopar stroker engines all the time. There are usually three or four of them in process. They usually end up costing between $10K and $15K depending on the parts used. You can build a good street motor on a budget but you have to be super careful about part selection. It is best to work with a shop that has experience since they'll know what works and what doesn't. A lot of parts are junk these days, even some of the good brand names have gone down hill recently.
If I was going to do a 512 low deck I'd use a stroker kit that had a piston that was less than 10:1 compression with a TF240 head. Use the TF240 head, a Performer RPM intake, a small hyd roller cam, and Comp steel rocker arms. Those engines usually make 600 torque and something in the 550 range for HP. You can easily make more HP with a bigger cam and a single plane intake, but the street manners get a lot worse. Just depends on car weight, rear gear and how rowdy you want the engine to be.
Someone is getting ready to build a big block.
It's funny. The thread title says "strong 400 build" but you're asking about anything but a 400. lol
ok, Ill bite,
"a strong , 400 cid, low deck, Mopar block, bored and stroked to various CID configurations "
Not mine bit I found someone selling a fresh build with dyno video on facebook market place. It made 600 Hp at 6,000 rpm on 91 pump gas. They are wanting 10,000 for it. Is that a good deal or not?
That is definitely a good deal considering about $ 2800.00 of mine is just the intake and carbs that's not even counting what it would have cost to weld , port the tunnel ram & resurface all machined areas
It is a fair price if it was put together correctly with decent parts. Before buying it you should ask for a parts list and look over the receipts.
