HOW DIFFICULT IS IT TO REPLACE MY 67 BARRACUDA DOOR HANDLES
soonercruiser
Oklahoma City, OK
I have ordered replacement door handles for my 67 Barracuda.; mine fairly pitted.
I have done a lot of DIY work on it.
But, I just want to get a reading on how much trouble I can get into replacing the door handles myself.
Did you read thru link I posted? Take pics prior to disconnecting linkages. Maybe spray clips with silicone to help keep them from breaking.
Are you sure you linked the correct story?
Most all that was about the doors and hinges.
I did find a good video on YouTube though.
I'll probably tackle the non-driver door handle first.
I did this last year. It's a little fussy trying to get the screws (on the back) started against the spring pressure, but it's not complicated. Be careful not to damage the door panel when removing it — it it's an original panel with original clips they will try to rip the board instead of pulling out cleanly from the holes.
I've swapped from clips to velcro. Way "better"
And don't leave out the sheet plastic that's between the door panel and the door. That's a moisture barrier, keeps moisture off the door panels, and keeps them from warping. Found that out the hard way back in my misspent youth.
Sorry, I thought there were door linkage pics in there. Do a search, it's not rocket science. 2 bolts/screws hold handle to door and I believe 1 rod.
Thanks anway.
I got lucky and found a good video, that even explains what to if the aftermarket outside handle levers are longer than OEM, or off angle.
