4-bar / back half the HemiDenny / HDK way
Thanks, I remember Tim mentioned your build and asked about the mount a few weeks ago.
The biggest reason I take on a project like this Dart is to learn how current upgrades / changes pan out and start thinking on what to improve for next time. While the first version of the crossmember / transmission mount was built specifically for this 6.4 build, the next version (already at the laser cutter) 8HP70 A body 2.0 mount will be slightly different to accommodate "stock" (higher and rearward) engine location.
Definitely keeping and extending the height adjustable loop. Small pilot holes are located in the loop to facilitate where to plug weld or tap / bolt to the floor pan. I am a fan of flexibility for updates and changes so while welding is great, it could be a PIA down the road.
Can't say that I can disagree with flexibility.. Probably even more so, you being the vendor and having to think about the end user.
Personally, I Have to consider what I might regret or change down the road... or the wishes and ifs that will follow. Hindsight can be a booger. But, when I'm at fork in the road, I just have to pick a direction and run with it, or I can think myself into a frenzy.
Eager to see version 2.0 when it comes out.. Still not sure it will work for me, due to my engine/trans location. Well.. work without mods. I'm somewhere between stock and the forward design that you have. I moved forward enough to clear the firewall but the Borgeson ps box would only let me go so far. One of those things that I really wish TTI would've put more thought into.. that damn tube #3
Just a daily that likes to play on occasion and something to work on in the winter on weekends.
clean sleeper ya got there.
square or rectangle tubing would have more to offer if you are trying to bend it in half..... but that is not what I feel is the function of the connectors. I am looking to control / stop torsional twist.
round tubing allows welding the top portion of the tube to the chassis which gets difficult to do with a flat piece close to the floor.
I used 2 x 3 rectangular on my silver Duster, US Car and Tool connectors (not a fan) on a customers Hemi Dart, then I noticed the 1-5/8" chromoly tubing on the Butch Leal Modified Hemi Duster with hundreds of high rev / HP launches with sticky big slicks and the body remains perfect. So I replicated it on his street Duster and two current projects, this Dart and a Hellcat Road Runner.
Butch's street Duster pictured.
Is it an optical illusion or do the frame connectors have a slight bend in them, on Butch's car?
one or the other but I do not know, the owner of the car just sent it. Guessing it is a Charger. I think I used one OEM hole (drivers side / top) ad drilled the rest.
I needed to bump this to the front page to help answer a few questions.
Hey HD,
I was looking through this build and noticed no torque boxes. Did you add them later or not use them at all ?
If not, was there any particular reason to omit them?
Also, using the front tires in the sizes you selected, is there any front chassis rubbing at full lock or any fender rub with wheels fully turned going lock to lock?
Thanks for any input .
Cheers!!
Hey HD,
Cheers!!
Since this Dart has been converted to a 4-bar with frame connectors tied directly to the 4-bar mounts, I removed the torque boxes. IMO, the sole function / purpose of the torque box is to mount the front of the leaf springs on.
The Dart owner bought the wheels and tires long before the Dart came to HDK, I just made them fit. Amazingly, it will turn loc to loc with clearance.
