1967 Dodge Dart Starter Relay wire question
nsantos1
usa
Hello everyone I just bought a Nos starter Relay and need to know about this green wire position or location
I assume is a ground to the relay!
Any information will be appreciated.
Thank you
Is the green wire attached to the relay? Originals didn't have a ground wire, no need for it. Cut it off.
Alan
It is probably there for manual transmissions that may not have a neutral safety switch.
Alan
Instead of having two relays.......one for auto trans and one for manual trans......they just make one replacement and you use that wire to ground one of the terminals for manual trans use. The original manual trans relay had one terminal soldered to the relay housing.
