dibbons
I have three different styles of oil filter wrenches and they are all hiding from me. Don't really want to use the screwdriver stab.
Ya did better than me! I couldn't find my stash of new oil filters for the JD mower last week, so I had to run into town and buy a new one.Then it took me another 20 minutes more to find the oil filter I knew I had in my hands just a couple of days ago (lol).
I don't know about your JD, but mine with the Kawasaki is a turd to get to. I have one that is a bit longer which helps and I found a fluted cup style wrench for the end of the filter.Ya did better than me! I couldn't find my stash of new oil filters for the JD mower last week, so I had to run into town and buy a new one.
Of course when I was cleaning-up I remembered where I put them.![]()
Nah! This one's a piece of cake to get to (zoomed-in interwebs pic below). Hardest part is remembering to set the brake pedal, and finding the special drain pan that fits between the front wheels and the mower deck underneath.I don't know about your JD, but mine with the Kawasaki is a turd to get to. I have one that is a bit longer which helps and I found a fluted cup style wrench for the end of the filter.
that's the long filter, thought A-bodies only used the short one...FYI the old filter was a Napa Gold 1515.
I don't even remember seeing the short filter back in the 1960's or 1970's. With the 90 degree adaptor, no need for a short filter anyway.that's the long filter, thought A-bodies only used the short one...
... Don't really want to use the screwdriver stab...
same here, first oil change small block 68 Camaro with headers. had to use a screwdriver but I was lucky it loosened it just enough to remove the whole (holey) filter.I tried that on my first car, a 1964 Dodge Polara 318 Poly. The metal did not hold and cut the filter in two. Had to have it towed to a local mechanic to get the filter base off. Those guys must have had a good laugh.
You just brought back horrible memories, when my sister asked me to change oil in the "new to her corvette"I tried that on my first car, a 1964 Dodge Polara 318 Poly. The metal did not hold and cut the filter in two. Had to have it towed to a local mechanic to get the filter base off. Those guys must have had a good laugh.
