How well did you hook up with the street tires and open rear? Its crazy how similar our ets are with many of the same parts (stock bottom end , Summit 272, bowled blended stock heads, Dougs headers , 9.5 PTC converter). A lot less miles on my short block ( about 80,000 ) than yours .Mine was LD4B and 650 dp, 3.23 suregrip with 275/60 ET Streets and I have a sealed air pan to the scoop. My converter flashes to about 3500. Was a nice cool day when I ran. My et slip for comparison :
I wasn't spinning, but I was aware of my situation and left the line accordingly, if you know what I meanHow well did you hook up with the street tires and open rear? Its crazy how similar our ets are with many of the same parts (stock bottom end , Summit 272, bowled blended stock heads, Dougs headers , 9.5 PTC converter). A lot less miles on my short block ( about 80,000 ) than yours .Mine was LD4B and 650 dp, 3.23 suregrip with 275/60 ET Streets and I have a sealed air pan to the scoop. My converter flashes to about 3500. Was a nice cool day when I ran. My et slip for comparison :
Cam specsYeah, the short block has never been apart. I believe it had like a 126, *** miles on it when I pulled it from my '76 Duster. Still has the smog 318 heads. Basically a summit cam and 4bbl to be honest.
DODGE Summit Racing SUM-1789 Summit Racing™ Camshafts | Summit RacingCam specs
How things have changed. Did you get a used carburetor and rebuild it? Brand / cfm. I really like seeing someone having fun and still not break the bank.DODGE Summit Racing SUM-1789 Summit Racing™ Camshafts | Summit Racing
Camshaft & lifters were 109.00 bucks back in 2016. Now just the cam is 174 bucks....
650 eddy carb. The original carb on the low dollar 318 was a used one but this one i bought new. I can't remember what happened to the original carb I had on there.. lolP
see how easy it is dan, when you get (that means go and buy) a basic car and warm it up a bitCongratulations on not only having fun but showing how it can be done on a small budget
Man, that's for sure. I'm going to chance my complete out look on this. I just did some quick math in my head and I think that I could do something similar to what 318willrun did for like $750-$1000.see how easy it is dan, when you get (that means go and buy) a basic car and warm it up a bit![]()
did you ever get a car to put it in?????Man, that's for sure. I'm going to chance my complete out look on this. I just did some quick math in my head and I think that I could do something similar to what 318willrun did for like $750-$1000.
Got a '71 dart to get hopefully, it's a project car but oh well some times that's what we have to dodid you ever get a car to put it in?????
so... no then?Got a '71 dart to get hopefully, it's a project car but oh well some times that's what we have to do
Unfortunately.so... no then?
Too bad some people spending a lot of time and effort trying to convince people otherwise,And keep in mind the entire purpose of the project was to show that on a limited - very limited budget a person can play and have fun. This was a 100% factory 318 2bbl that we put under 500 bucks into (including timing set & rattle can paint... lol) and went 14.9's with the worst of everything (2.76 gears, stock converter and exhaust manifolds) It's been set up like this since 2016, and we pounded (ground-pounded!!! LOL) for 8 years (and the bottom end has never been apart).
The Message: - go out and play!!!
Dan, come and get this one! Turn the key and take it straight to the track before taking it home!!!Got a '71 dart to get hopefully, it's a project car but oh well some times that's what we have to do
Which one you talking about?Dan, come and get this one! Turn the key and take it straight to the track before taking it home!!!
this thread Dan,, this threadWhich one you talking about?
How much??this thread Dan,, this thread
Post 31 has a video of it
