This isn't a "for sale" thread. You can PM me.....How much??
Seems like it was AJ that said he wouldn't meet his initial goal because , you know ,math.Too bad some people spending a lot of time and effort trying to convince people otherwise,
even though you given a easily obtainable proven blueprint to follow.
AJ said that about my 360 Duster... lol Said he'd blow his car up if I hit the targetSeems like it was AJ that said he wouldn't meet his initial goal because , you know ,math.
Here is the video...
LOL. I couldn't remember if it was the 318 or 360 car.AJ said that about my 360 Duster... lol Said he'd blow his car up if I hit the target![]()
I wouldn't have won without them.Looks like the slappers work good . I can imagine some cooler air and some more passes/tweaking/tuning knocking a few more tenths off.
I wonder how he rationalizes your builds against his V/P index.AJ said that about my 360 Duster... lol Said he'd blow his car up if I hit the target![]()
I told him and others before....... "it's all great and makes sense on paper, but my car just doesn't know how to read" .....I wonder how he rationalizes your builds against his V/P index.
Just maybe there's more than one to skin a cat![]()
That's a good oneI told him and others before....... "it's all great and makes sense on paper, but my car just doesn't know how to read" .....![]()
Congrats, sounds like you had fun and showed how a cheap combo will run! I'd be putting a cheap NOS kit on it and seeing what else it has, it'd probably run 11s without problems.Couldn’t be happier as the low dollar 318 project of 2016 gave its finale. We were hoping for 8.9 in the 1/8, and were really hoping so bad for anything in the 13’s. Completely unprepped, we went on a whim and here are the results.
8.87 in the 1/8, 13.97 in the 1/4. And, we took home the hardware!!!
LOL… but I’m not a NOS kind of guyUh oh. Sounds like a challenge!! @318willrun loves a good challenge!!!
Which is better High CR with low VE% or High VE% with low CR ?Id love to know what your cranking psi is?
I like the vp/index but my car was faster even when it went down
Cam Timing vs. Compression AnalysisWhat is the v/p index and how is it calculated?
AJ would be your man to explain how to calculate it, I get the premise but never bothered calculate anything.What is the v/p index and how is it calculated?
K. Thanks. I'll ask him.AJ would be your man to explain how to calculate it, I get the premise but never bothered calculate anything.
140…. At least back in 2016 when I checked it LOLId love to know what your cranking psi is?
There no question my 68 318 v/p dropped when i did 340 heads and street hemi cam but it was still much faster
when purchased
68 dart 270
318-2 headers duals 727 3.23sg
added dual plane 750 from a 440 faster again
then 2.02s street hemi cam torker door stop tuned 650 dp unilite faster again
then nitrous much much faster
Tunning makes a huge difference
Heck theres a guy on here with 380hp crate motor stall and gears running mid 14s so he says stock 340s cant run 14.3
318
13 second mopar bible build its what i used
smh
I can say going from the stock 340 cam to the comp 268h 218 218 454 110 106 its alot better low end cam and iam sure it raised the v/p index.Cam Timing vs. Compression Analysis
"*V/P (Volume/Pressure) Index is a mathematically-derived figure, the product of the corrected volume and cranking pressure. It’s a very useful barometer of the motor’s low-speed power, and may be solved with new variables for a “before & after” analysis when modifications are contemplated. Anyone planning a cam or compression ratio change would definitely want to know how much the low-speed flexibility would be affected. Some useful insight may also be derived as to the motor’s tolerance of pump-quality gas (ping & knock resistance). The results of these comparisons are generally quite surprising!"
There's no doubt about higher cr v/p etc.. gonna make everything better/efficient but doesn't mean you can build power with less than ideal, just need to displace more fuel and airBuilding a motor today i would use the vp/index as a tool to get the best of both worlds.
Great job!!! Super proud of you!Couldn’t be happier as the low dollar 318 project of 2016 gave its finale. We were hoping for 8.9 in the 1/8, and were really hoping so bad for anything in the 13’s. Completely unprepped, we went on a whim and here are the results.
I appreciate your kind words, thank youGreat job!!! Super proud of you!
You represent the hobby, yourself, and all of us here on FABO with high esteem. You are greatly appreciated!!!
