Litz
I'm having a hard time figuring what would be a good upgrade from the old single pot MC. Looks like the headers will be very close to the MC. Any suggestions/advice would sure be appreciated. Thanks in advance.
Yes, it's a street car with drums all aroundIs this a street car? Drums all around?
Posted a photoPictures would help
Yeah street/strip drum brakes all aroundIs this a street car? Drums all around?
How do you come up with these ideas? I'm still mesmerized by your new AVATAR...LOLWhat I would do in your case is three fold. First, as mentioned, upgrade to a dual reservoir master cylinder. Secondly, I would get the master cylinder relocation block for the Hemi. This moves the master cylinder over towards the driver's side fender for more clearance. Third, I would employ a shield to protect the master cylinder from heat.
I certainly don't disagree. However, IF there's a failure of any kind.....a rusted line lets loose, a wheel cylinder blows out, a bursted brake hose and all you will have is MAYBE one pump on the brake pedal to slow it down "a little" and if you have no parking brake, then you got "NUTHIN" after that one last pump. Yup, they work great for sixty plus years, but there's always that ONE time.A Single-Pot still shuts mine down after 60 years... If it works...
Oh, So a Dual-Pot will get you Two Pumps then? I get it.I certainly don't disagree. However, IF there's a failure of any kind.....a rusted line lets loose, a wheel cylinder blows out, a bursted brake hose and all you will have is MAYBE one pump on the brake pedal to slow it down "a little" and if you have no parking brake, then you got "NUTHIN" after that one last pump. Yup, they work great for sixty plus years, but there's always that ONE time.
No, much more. You don't understand how it works. A dual reservoir master cylinder splits the front and rear braking systems into two separate systems. I can cut a front brake hose IN HALF and although you will lose the front brakes completely, it does not affect the rear AT ALL. You still have full rear brakes and can stop the car. Same for the rear if they become disabled. You will still have brakes, although the pedal would be low, you could still stop.Oh, So a Dual-Pot will get you Two Pumps then? I get it.
Nope. Red X. LolNo, much more. You don't understand how it works. A dual reservoir master cylinder splits the front and rear braking systems into two separate systems. I can cut a front brake hose IN HALF and although you will lose the front brakes completely, it does not affect the rear AT ALL. You still have full rear brakes and can stop the car. Same for the rear if they become disabled. You will still have brakes, although the pedal would be low, you could still stop.
If they do, you've got something wrong. It's not up for debate, sparky. That's how it works. That's why dual reservoir master cylinders were mandated in 1967. You're right though. On a single reservoir master cylinder, no matter where you open the system, they go to the floor.When you open a Bleeder they go to-the-floor I don't care how many ports you got.
Haaa! I got a New ScreenName.wrong. It's not up for debate, sparky.
