Any guidance on my 1970 Duster plans
Well it has the right heads and valve gear. Where's the Six Pack? Is T/A cast into the block?
He's got part of the TA puzzle. The block is the other part.
Nice get without a doubt if it was had for 1K. I get the part about not selling it because you are supposed to use it. As a seller of stuff like that and the "story" sold by some buyers to get things, then see the part for sale somewhere else for a bunch more than you let it go. Nice way to burn bridges. :) Good approach, although if it was a complete TA long block, you could definitely fund a LOT of stuff. Guessing it's in the 6K+ range with a TA block. Nice find
If it is a TA block.
A suggestion if you are close to the seller. Get with Barry Washington at The 1970 Hamtramck Registry Home Page
Look here if there for the last six of the vin The 1970 Hamtramck Registry - Found Section - By Year/Plant (1970 -1979)
Give him the VIN on the block, pass side oil pan rail near the block drain plug. If he has any records for the car it came from, still being around, see about getting it back to the original car. He has info on cars that are not listed in the "found" section.
Run that by the seller and give him some proceeds from that potential sale, sale minus your 1K you gave, then split 50/50, you 70 him 30, whatever the legwork to get it back with the original car. Makes it a win for 3 people in that case.
Here’s a biscuit motor mount V8 K frame. You can mix / match some of the parts from 76-72 and 73-76 K frames.
@poconos_power
That sway bar mount will break off. Not where it should be attached. Not sure if anyone else already mentioned that.
It mounts over where the K frame diagonals for the frame rail. Right below where the strut rod is sticking through. You can see the two bolt holes in the pinch lip.
@poconos_power
Agreed. The FF mount is further out by the front horn and is triangulated for better sway bar support. They (FF) also have bolt on lower control arm (LCA) brackets so you don’t have to use the factory arms with the brackets already on them.
Thanks for the rundown @72bluNblu thats a lot to think about. I'm getting a way better idea of what goes into this. Really appreciate the time you took to lay that all out. I think starting out I'm probably not going to be as serious as you, but it looks like theres a lot of tinkering to be done as time goes on.
Seems like starting out it'll be worth it to find a 73+ spool k-member instead of trying to reuse the /6 member in there now with conversion mounts. Looks like theres options out there too! Which is great.
Glad everyone confirmed that sway bar is installed wrong, I had my suspicion when I first saw it. I'm happy to say, I didn't do that. I'll need to check how it's attached to the LCAs.
And look, with the TA engine, I had to go again tonight and check the block casting, yes it's real, and yes I'm still planning to use it. However I may check the registry just in case, why not?
The way I read it the seller sold him the engine weather it is a 340 with sixpack, slant six, or a 426 Hemi under the agreement to personally use it. Instead of the engine just sitting, it would be going to used by him personally.
The last things I sold I in no way would have practically gave away. I was lied to by buyer's stating they needed it for personal use. Prices were to help them out with their projects. Only to see them right away sell the stuff I gave deals on based solely on the fact it was helping them out with their ride. Some stuff was even begged, I need it sell/give me it.
So when I read guys say sell it that's just not cool. It was bought with the intention of the buyer using it.
You want a V8 K frame. Either 68-72 or 73-76. It does not really matter which one, but there are a few idiosyncrasy you have to know about.
The early K frame 68-72 has biscuit motor mounts and if with a sway bar, the bar mounts similar the one in the photo. (67 k frame can be used but is one year only and has only one idler arm ear)
The late K frame 73-76 has spool mounts and the sway bar passes through the center of the K frame.
The lower control arms without sway bar tabs will work with all the years. The the LCA with tabs are early / late K frame specific.
There are 2 size upper ball joints in the upper control arms. This dictates what spindle is used unless the spacer sleeve is used.
The center steering link is a little different between the change over mainly the angle where the inner tie rod connects.
The big one is you have to find a set of 340 motor mount brackets as the 360 and 318 are a little different.
I'm not a fan of the early biscuit mounts. If 1 fails it will cut into your upper radiator hose unless you add a strap or I use a small chain with a bicycle tube for a liner attached to K frame and engine mount bolt. The quality of the mounts are crap now unless you buy the truck mount type but raises engine height (I'm not knowledgeable there) or go solid mount. The spool mounts won't do this.
Finally to everyone saying "sell the TA"... No. :) The reason why has a few aspects to it. The guy who sold it to me did so because he thinks I may just be able to get it running in a car that he'll be able to drive at some point. I got a sweet deal of $1k for it, but with the understanding that I'm going to keep it and use it. It was rebuilt almost 45 years ago, driven around in a Cuda for a bit (not AAR) and then him and my uncle removed it before a road trip to preserve it and well... time went by. Didn't come with a 6 pack intake, but thats ok. Finally, I think it's cool and it'd be neat in this car. If I ever think I'd run it too hard and destroy it, I'll pull it to use on something else, but till then I like this motor, it's the thing that kicked off this whole project, so I'm putting it in.
Good for you:thumbsup: A man of his word is a rare commodity these days.
I'm a fan of the '73-76 spool mount stuff.
Like @Kendog 170 said, they don't break.
Plus the sway bar is a better design with it's shorter arms, better mounting and it doesn't interfere with wide tires or the later brakes. There is an aftermarket swaybar for the biscuit mount k-frames that uses the later LCA, but it still has limitations.
Note that the '68-72 steering works with the spool mount k-frame, you just have to swap (or keep) the idler, pitman and centerlink all together. The later parts have the benefit of working better with the G3 swap, but it doesn't matter with a smallblock.
For what it's worth, I am doing a G3 swap into a '73 and will roll down the road the first time with fairly stock suspension similar to what you might be thinking about. It's one nice thing about doing a TB suspension, you can make the car drivable and do upgrades over times, compared to a coil over conversion where it is a big hit to the wallet from the get go.
I would do some basic upgrades from the start though, including gusseting and fully welding the k-frame and doing subframe connectors. The motor is out so it is a great time to weld in subframe connectors without the weight of the engine flexing the body. And pulling a k-frame later to gusset/weld it a pain.
After that, put whatever parts you need on it to get it rolling. Only caveat being that if you need new parts, it might be worth springing for some of the upgrades so you don't have to (in theory) buy them twice.
And then go autocross it. Don't wait for the final iteration of the build or worry about being competitive. Go enjoy it as it and get some miles under your belt. Upgrade it as you see fit and enjoy the improvements over time rather than daydreaming about "someday".
Get the VIN number off of that TA block and post it up on www.forebodiesonly.com and https://forum.e-bodies.org a decent chance that somebody might be trying to find that block to match up with their vehicle, this brings extra money. Either way, I would either sell it to a restorer or trade it for a built 408 stroker motor. Tuning the carbs on a six pack is not exactly fun, so you'll be doing yourself and another restoration a favor.
Hey everyone! I was recently lucky enough to pick up a 340 TA engine that has been off the road for about 40 years (going to need to get sent out, but it's complete). It belonged to my Dad's friend and his wife finally convinced him it would go better in a car than sitting in their garage. So I did what any reasonable person would, I bought a car to put it in. I ended up finding a 1970 Duster that was originally a slant 6 automatic. I got lucky the interior is great and it only needs small rust patches in the rear quarters, then I may send it out for paint.
In figuring out what I want this car to be, I have never done a performance build before, and was thinking autocross seems like something I want to do. Though I also want the car to be able to cruise and do road trips and such. So I'm looking for it to be good at multiple things but not great at one thing I suppose, I'm sure my limitation will be my driving skill instead of the car in the beginning, I'm just something that works and lets me get into it and would be an interesting project to get to my goal. I did some research and there are plenty of great options for full coil over conversions on the front, and I'm sure I could do that eventually, but I find the prospect of trying to tune in a t-bar suspension more interesting. I figure I can always upgrade and change in the future. So after a few weeks of lurking and reading here is what I'm thinking, and please let me know what you think about this.
For the rear, I was able to score a new 8.75 rear at Carlisle this past summer to upgrade the previous rear. I was thinking of putting in the Hotchkis geometry corrected leafs.
For the front, I was going to do the Firm Feel reinforcement kit for the k-member, reinforce the lower control arms, get the Firm Feel tubular uppers with the big ball joint (if I replace the spindles), and adjustable strut rods. Poly bushings for everything. Also the car has a pretty big front sway bar currently, though I haven't measured it, but I don't think it's original.
For torsion bars I was thinking 1.08 or 1.12 based on what I'm reading here. However the question is, how do I address the 1" drop from the Hotchkis leafs? Do I get drop spindles or just drop the front using the torsion bars?
And finally I'll replace the power steering box with a better ratio. Perhaps at some point I'll also add frame rail connectors and torque boxes, but I'd like to get driving down the road first at least.
Any thoughts out there about this? I've read a lot of posts saying if you set up a torsion bar suspension correctly, it can be on par with a coil spring setup, but I haven't found the full breakdown or how that can be achieved. This is what I've pieced together from various posts. Thanks!
Looks like a nice car to start with. I became addicted to autocross almost 4 years ago. Don't worry about being the fastest out there, because chances are you never will be. You will, however, have the coolest car there! I wouldn't worry about the ride being too harsh if you go with large torsion bars. It's all about the shock you use to control the big bar. That's the beauty of pro-touring cars, they can handle on the autocross and drive to and from the event with a perfectly comfortable ride. The same can't be said for the guys that go "street/strip". So many people buy into the Super stock springs or caltracs and use drag racing shocks when in reality they never go to the track. I've had that setup, it rides like a tank. No thanks!.
Others have done a good job explaining what parts work well, so I won't go into that. I've run the torsion bar recipe outlined here and it works very well on the autocross. (I have an HDK coil over setup now) Maybe not mentioned here is the importance of alignment. You will want at least 6.5+ of caster and maybe .5 of camber to start. If you decide to do more autocross, you will likely want to bump up the camber. It's been very surprising to me how much difference an alignment can make. Here's a photo of my car. Notice the front tires are nearly vertical, particularly the one outside front and the inside tire still has good contact with the ground.
This is an extreme circumstance, but I wanted you to see what a standard alignment looks like.
I think it's hilarious how butt hurt people are getting over the T/A engine and on the suspension forum at that. Please rebuild it and put a single 2bbl carb on it just get their panties further up their ***. While you're at it, paint it Ford blue or Chevy orange.
I agree maybe John Deer Green?
When I was 17 I was on a budget and had a 2-tone motor.
I ordered a Rebuild kit from PAW {rings, bearings, gaskets} put in a used cam/ lifters and my aluminum intake/carb. I had to borrow a drill as mine burnt up, to use the borrowed dingle berry hone to break the glaze. Someone gave me 2 old cans of paint one black that was just enough to shoot the heads. And my buddy gave me a partial can of VHT yellow. So, the block was yellow, with black heads. My young Chevy friends thought it was a Mopar thing The "Bumble Bee" HP motor was cleaning their clock. They all knew it was a fresh motor, and it ran very strong. But was a just a junk yard 340 from a wrecked car, but guys thought it was some special motor.
I think a 1973 up spool mount K Frame, Sway Bar that pass through the K frame, Add the tabs on lower control arms for it, 73 up and disk brakes. And a rebuild of the motor he has, will be a good runner. Build it with common parts easy to get and the engine he has.
He can always upgrade later.
Might as well top the package off with a six pak if you have the extra bread. Just my opinion of course.
Nothing beats a six pack if you want eye candy, if that's what you are going for eye candy
But a simple LD340 and easy to use AVS Eddie or AFB (I think the AVS Better) would but won't have the I am fast sitting still look.
But has the classic look and I like retro cars.
Could also do the Holley, Air Gap thing for the Chevy look.
Managed to get a late spool style k-member cheap, but with no LCAs. I haven't checked how my sway bar attaches to my current ones as I haven't felt like rolling around in the snow. Why is it that the sway bar tabs make the LCAs year specific? If the ones I have are too early, and I have no reason to believe they aren't original, I guess I'll be looking for a new set once I see how the sway bar connects.
I've got some other projects I need to find a machine shop to make progress with, and I'll just take this k-member over with all that stuff and get it hot tanked.
67~72 bars mount on the front of the K and are wider and pick up the LCA tabs outward and low toward the wheel
73~76 bars go thru the K and mount in the notch portion where they pass. they are narrower and pick up the tabs on the 73~76 arms in the near middle of the arm up higher.
aftermarket bars mount to the K and generally pick up to a tab that's bolted to the lower shock pick up, or they utilize weld on mounts specific to the mfgr.
what bar you run will affect what brakes you can run-- or how those mount.
Nice! Get it gusseted and you are golden.
Your current LCA's will work if they don't have the early sway bar tabs or remove them if they do. Just weld these on:
Hotchkis Sport Suspension 23367 Hotchkis Sport Suspension Sway Bar End Link Mounting Brackets | Summit Racing
Here is an idea of where they are located:
I can get you a measurement if you wanted to weld them on without having a strut rod in them.
Another option if your LCA's do have the early sway bar brackets is to sell/trade them for a set without any or with the later brackets. Yours should have some value to the right guy if they do have the brackets.
Add these while you are at it:
Lower Control Arm Stiffening Plate
Ok, some progress, I did manage to get a 73 V8 k-frame, as well as LCAs to go with it. That stuff is out getting cleaned up and degreased so I'll be starting to weld reinforcements on those in the next few weeks. My wallet is a lot lighter as a bunch of stuff has been ordered, with a bunch more yet to be ordered. Been creeping around here reading and trying to learn where I can. One question that I have, I notice a lot of guys run b-body 8.75 rears for autocross builds. Why is that? Whats the advantage. I picked up what should be an a-body 8.75 at Carlisle last year not quite yet knowing where I was going with this car just that the original slant 6 rear was not going to work out long term.
Also, I'm starting to think about tires and brakes now too. I suck at wheel/tire planning, still a skill I'm building for sure. I notice there is a lot of effort put into the 1/2in leaf spring relocation. Does that really make that big of a difference? I looked into it, and it seems pretty straight forward with the exception of moving the spring perches on the rear, which may be beyond my ability right now. I have a better shot at pulling of a reverse tub like @72bluNblu did, but just barely. I'm going to have the thing painted so I'm trying to figure all this out before it goes out.
I've got the suspension figured out for the first iteration (well, good enough anyway, just need to keep buying stuff for now) and I really appreciate all the help and suggestions. Once anything interesting happens I'll throw some photos up, for now its just outside in the snow.
Not sure what the advantage of using a B-body housing (maybe have more wheel options because of the back spacing?)
I wouldn't worry about moving the springs, Dusters have large wheel openings and you shouldn't have a problem with rubbing.
