Voltage regulator smoking?
Thank you for all the advice, as you know I am a bit unexperienced and a little confused but what I need to do is to just pony up and focus on the task at hand, use all the resources you guys have given me to figure this out thank you for all the help. but truthfully I may need a little local help. I installed the regular using how the old one was installed as a guide
If you can't get local help, I think your best bet right now is to follow the advice given on tracing out the schematic and start asking questions when you get stuck. Don't worry about if you think it's a stupid question or not. A few answers later and it'll unlock your ability to start understanding what you're troubleshooting and by the end of this thing, you'll get a good grasp on troubleshooting electrical problems. If someone is giving you advice and you don't understand it, just tell them and see if they will simplify it for you. Prerequisites are required for a lot of "car talk" and most 16 year olds just don't have them yet. Don't be afraid to admit that you have no idea what the hell it is that we are talking about lol
If you try and throw random parts at it and play the guessing game, you'll wind up wasting your money, time and frustrating the guys trying to help you. Plus you'll learn very little that way. Start asking away.
Ok so I took some stuff apart
Me and my dad where thinking we were going to bypass the bulkhead
I agree with what @ESP47 wrote.
And what you wrote as well. The tools are there, but your don't know how to use them until you study them a bit.
You have the real thing in front of you. You've taken some stuff off. I think that's good because at least for some us, the book makes more sense when we see stuff in real life. Then go back to the book again. Or in the case here, go to the book and also search this forum for photos of how things should look.
The Voltage Regulator install. There's two different types of voltage regulators. Your car came with the type you removed. It works with a "grounded field alternator". The explanation and photos are in this thread. The alternator on your car appears to be an isolated field alternator. One of the field terminals should be grounded. In the photos it does not look like that was done. We can't see what the field terminals are connected to. That could be part of the problem. This is one of the things that you will discover by following the wires and seeing what they connect to. There's lots of ways to follow a wire.
Well you still have to find the problem. The bulkhead is not the cause, it is showing the effect of some thing(s) gone wrong. It may be as simple as the v-regulator points stuck but from what we see it may be the way the wiring was modified.
Finding the parts will not be too hard. '66 may use the bulkhead connector as '67 and several subsequent years.
If you really want to take it all out, then label and stretch it out on a bench or large board.
Lots of good posts on the forum about removing connectors, replacing terminals and even rewrapping bundles.
But I think you should first figure out what is going on with the current set up.
Speaking of current, I suspect that may be part of the mental block.
Lets put this to rest. Its not that hard of a concept.
Current is electrons moving or flowing. The more electrons moving, the more current. No electrons moving, then there is no current.
Like a river the current can split into smaller rivers.
Voltage is the force, or more properly the potential energy for the electrons to move. Only when there is a circuit connected from positive to the ground can the electrons move. So everything off, the battery has voltage, but there is no current.
The damage we see is from too much current through those connections, which may have been caused by too much voltage.
For the purpose of trouble shooting, follow the path the current must have been flowing. You saw the meter show very high current into the battery. So that is a good path to begin with investigating. Then follow it back tothe alterernator.
The book will show what wire goes in each of the connector positions. So there is more information there.
Thank you very much I will examine the book and I will follow the path to the alternator
looking into the dash it really does look like someone unwrapped parts of the harness to trace issues, made some fixes and then just stuffed it all back up under the dash. The wire insulation looks so fresh and unfaded that it must have been protected by the wrap.
Question to some of the early A gurus here - in the first pic that looks into the dash there is a 5 wire connector that seems to be missing a bunch of wires - is that for the dash cluster or maybe one of the column harnesses?
I'm not sure what we are looking at on the engine.
The two resistors are a part of the 1970s era Electronic Control Unit (ECU) for the ignition.
Unfortunately when that was added, the factory wires and colors got changed, and one of those the Ignition Run wire J2 is shared with the to the voltage regulator. So you'll have to figure which wire that is, even if you don't touch the ignition.
That's the automatic choke control.
Yeh you for sure have a problem on your hands. if things get too bad on the bulkhead connector, and you are not terribly fussy about "restoraton accuracy," you could pull the bad wires loose, either splice to them for slack, or if you can generate slack, pull the terminals out of the connector, snake the wires through the connector and just semi permanently splice the two together. Way way back in the '70's my 70 RR ate up the connector where the ammeter wires went through. I just reamed out the connector body with a drill, snaked wires clear through the connector, and connected them up.
I believe I said before, judging from what we can see, things have been warm. Be particularly aware, that wires wrapped together can "cook" in the wrap, and melt insulation, melt wires together and form unwanted shorts/ crosses between wires. THAT can be a nightmare to find, in a hidden, hard to reach section of harness
