Replacement 68 340 four speed cams
My 99.9% stock 340's would run 14 flat go 165 and get about 20 mpg on snow tires with no posi. no o.d. Stock exhaust system. I have plenty of witnesses. There may be some better stuff out there but it always worked for me. Now add 1.6 rockers, 11.0 to 1, o.d. 4.10's headers etc. what would you get today. Add a high-pressure fuel system. Wow just imagine what you'd get out of that little 340 with a 55 year old cam. O, with 55 year old heads to boot. Now ...
I know you are in MI, if near Detroit, is it in Kilometers per Hour by chance? Some Canadian cars have Km/h speedos
I believe the formula for top speed HP goes as:
($ x APR) + 5W = S x .99, where
APR = variable
5W = lodging
S = speed
.99 = "I'll be back next year" coefficient
And: I think it goes... all the power you can afford dose not go as fast as you want.
From Carroll Smith's book [Tune to Win] Drag HP= CD X Frontal area X ( Velocity in mph) to the 3rd power divided by
146,600
His example Drag HP = (.65) X ( 17 FT) x (180 mph) to the 3rd power OR 180 X180X 180
146,600 = 439 HP
It is proportional to the cube of the speed. The force due to drag is proportional to the square. To get power you have to multiply by the rate. Therefore the power is proportional to the cube of the speed.
If it takes 100 hp to go 100 mph then to go 200 it is the ratio of (200/100) cubed times 100 hp or 800 hp.
Don’t let math or science or any of that other nonsensical stuff ruin a good story.
Well I'll give in. 12 Impala, little 240ci, n/a, tires do weight 70 lbs ea. Power windows, power brakes, power locks, power drivers seat, power trunk, ac, cooling ducts for frt. brakes (did I give it away?) 100% factory stock with cat conv., almost 200k, runs 14's, turns 6700, and extremely limited to 151. H.P. must be at least 650 according to the sq. root to the square root. but Chevy must have got it wrong at only 300. But 300 from a 87 octane 240ci with 280 lbs. of rolling stock? HOW? WHY? O and it does circles in city streets and much more. WHY? O yes old ppv cruiser.
With the 2012 impala numbers @junkyardhero posted I show you need about 218hp to go 151. Isn’t aerodynamics amazing? There are some assumptions here and I don’t know downforce so……..
The formula data sheet I made says roughly 385.6hp for a 68 Dart to do 165 based on frontal area, drag CoD, etc. And 434hp for elevation at Bonneville.
Now, once you have the HP to overcome drag, with the tire size and gear ratios...
There was a time I had my big block Camaro out playing. 454 4spd 26" tires 2.73 gears. I passed 3 telephone poles in 5 Mississippi's which is perfectly calibrated to 120mph.
welp. case closed. eveybody knows that 340's came with 400hp from the factory no matter the vintage and no matter the day of the week they were built on!
146,600
146,600 = 439 HP
How come Hellcats do it with 700hp? Maybe a Monday build. :)
