Costco. Best warranty
X3If you want a spare lead acid battery go to Costco . They sell Interstate batteries at low prices.
I've had two lead acid batteries " blow up" in my lifetime. Acid went everywhere including my eyeballs and face landing me in the ER, a stay at the hospital and a week off work with patches over both eyes on one of the occasions. The other just got acid all over the fenders and under the hood. Luckily there was a garden hose close by to flush the acid off the paint on that incident.do they blow up and burn your car to the ground like an EV?
I've had ONE do that. I was standing on one of the ramps over a front end alignment pit on the edge of the ramp. The pit was about 5 feet deep. I was loosening the control arm shaft nut to move some front end shims around (GM product). The end of my ratchet came in contact with the positive stud on the starter grounded to a direct short and the battery (right under my face) exploded. Somehow I managed to close my eyes in time enough to avoid getting acid in them. I had to call for help to jump from the ramp to the side of the pit so as not to fall in the pit and was helped to the bathroom where I flushed my face down. I also had to change work shirts. That taught me right there that if I opened the hood, the negative battery cable got disconnected.I've had two lead acid batteries " blow up" in my lifetime. Acid went everywhere including my eyeballs and face landing me in the ER, a stay at the hospital and a week off work with patches over both eyes on one of the occasions. The other just got acid all over the fenders and under the hood. Luckily there was a garden hose close by to flush the acid off the paint on that incident.
I have lithium ion batterys all over the shop In my battery operated tools and in my cell phone and who knows what else. So far, none of those have blown up yet.
Yes. It's 9 years old and its cranking power is down. Not sure how much longer it will last.is there anything wrong with the battery you have in it now?
My repro battery is losing its cranking power. The new ones are around $350 plus shipping. I was thinking I could keep using the old one until it fails completely, but have a modern battery in the mean time so I don't get stranded somewhere.Exactly!
Bob/@cruiser:
I know how you want to keep your Duster as OEM as possible (and you've done a heckuva lot of work on it for that very reason), so what's wrong with the battery you have now? It looks the part, and you could always get another one if this one is going bad....
Gotcha!My repro battery is losing its cranking power. The new ones are around $350 plus shipping. I was thinking I could keep using the old one until it fails completely, but have a modern battery in the mean time so I don't get stranded somewhere.
Thanks! I'll keep that in mind and will let you know if I decide to go the NAPA route.Gotcha!
I used to manage the NAPA down in Savage, on Hwy 13, but that was over 25 years ago, so I don't know anyone there anymore. I do, however, still have an "in" at the NAPA up here in Osseo, if that would help you...
If you still have my number, feel free to call anytime!Thanks! I'll keep that in mind and will let you know if I decide to go the NAPA route.
Well don't throw it out, just cut the bottom open and put a new Odyssey PC925 inside.My repro battery is losing its cranking power. The new ones are around $350 plus shipping. I was thinking I could keep using the old one until it fails completely, but have a modern battery in the mean time so I don't get stranded somewhere.
I didn't know you could do that. Will search around on YouTube to find a video showing this. Thanks!Well don't throw it out, just cut the bottom open and put a new Odyssey PC925 inside.
You don't need to search Youtube, I've showed it at least 3 times on FBBO.. I'll go find one for you.I didn't know you could do that. Will search around on YouTube to find a video showing this. Thanks!
They could!
Oh wait they blow up some times too... (happened to me while starting a 91 Ford E 250 from inside the cabin while just turning the key)Note If you go down the battery topper route, what ever battery you buy be sure it does not have raised caps or sunken posts or the battery topper will not fit.My repro battery is losing its cranking power. The new ones are around $350 plus shipping. I was thinking I could keep using the old one until it fails completely, but have a modern battery in the mean time so I don't get stranded somewhere.
I just said they could. Not they would, dummy. ....and they could.Just like the LI batteries in your garage right now for all your battery powered devices. I guess you best go remove and toss away everything you own with a rechargeable non lead acid batteryOh wait they blow up some times too... (happened to me while starting a 91 Ford E 250 from inside the cabin while just turning the key)
Li gets a bad rap. Its not perfect and it gets sensationalized in the media when ever there is a fire, unlike the more plentiful gas and diesel fires.
https://www.motortrend.com/features/you-are-wrong-about-ev-fires/
who you callin' Dummy... Well ya I guess that fits!dummy
I'll share it so you can use it back. lolwho you callin' Dummy... Well ya I guess that fits!![]()
HD is also way cheaper for motor oil (sorry I did not mean to hijack the post)Found cheaper than anywhere else of all places Home Depot!
Before it gets to that, if there is an ammeter, adjust the charge rate (on some that means dropping the supply voltage) so the charge rate is down around 15 amps or less. My understanding is the maximum safe charge rate can be estimated from the battery's capacit and a Rule of thumb frequently posted is 1/4 of Amp-hr rating.if you charge a almost empty Battery, the batterytemp should NEVER exeed the temperature of a human body! If you cant touch it, disconnect immediately. Most new charger dont charge low volt batteries. Smart people try to lie the charger with a 2nd batterie parallel switched. This can be dangerous. If you want to reactivite a battery, use a low amp charger like a Ctek or so.
Remove from the car and charge in a safe place. The only reasons for exploding AGM and lead batteries are open flames, shorts and overcharging 15+ Volts. LiFePo Batteries have a internal relais and balancer. They open at low or high voltage.
I feel fine with
AGM batteries, Optima (i hate the design) and a small charger like
