After installing the newly rebuilt z-bar, I find that the two ball studs are not aligned with each other.
They are not on the same front-to-rear line. It looks like the bell housing side is too far forward or the frame side is too far back.
Since this car was probably converted to 4-speed by a PO, I suspect that the hole for the frame side ball studs was not drilled in exactly the right place, hence the misalignment. That end will certainly be easier to correct than the other end; maybe the only way to correct it since the whole drive train ain't gonna shift to accommodate.
). The keeper spring, seals, plastic bushing/bearings came in a kit from Year One in Mopar bags and they all fit perfectly. The fender side ball stud matches the size of the old one.
