Opinions wanted for replacement Rear Spring selection. Thank you
Anyone used the HD leafs that Mancinni Racing sells? im looking at those for my Barracudas
I have them on my Duster, they sat kind of high, I added a lowering block to get the look I wanted.
I over-torqued cause i'm a moron and honestly never had used a torque wrench on ubolts and never noticed a problem, springs were like buggy springs and i couldn't budge the rear end, like 1" even.. torqued them properly and it settle bout 3" and moves like butter now. It does make me wonder how much better cars in the past i had could have felt/handled..
Getting ready to put my new Espo springs on my 65 Barracuda this week. I'm trying to educate myself more on all the torque chat. Espo specifically says not to torque the shackle bolts. Other information I've seen says 45 on the UBolts and 30 on the shackle bolts. Any idea why Espo says not to torque the shackle bolts? Thanks!
You could also re-arch what you have if they are in good condition otherwise. I've re-arched jeep springs with a hydraulic press but it takes time and care. You could also add a leaf for more rate or half a leaf (cut off behind the axle with a plasma torch) for a traction aid with different clamps for the thicker stack. Most older vehicles have 2.5" wide leafs but center hole size varies. I think the Mancini XHD set would be hard to beat off the shelf for $325. If you can get the SS for little to nothing, you might pull a leaf from the middle to soften them up and drop the car a little if needed. The longer
Rearching the original set guarantee us steel as opposed to chinisum steel
I had a 70 dart years ago that I put a set ESPO springs on the back. They were great. Unfortunately I did try to torq the stock shackle nuts and snapped the threaded end of the shackle right off at the step where the bushings go. Ever since then I get them tight and use a dab of blue loctite.
lower the front, it looks like somebody has stolen the engine....
front and rear spring should match the weight distribution, contact a good manufactor as recommended from the other guys.
The Jaundiced GT ('71 Dart GT) has ManciniRacing 2800lb springs on it. They were installed over 21 years ago (by the previous owner). The car also has the factory installed 8 3/4" rear end with WheelVintiques 15" X 7" (4 1/4" backspace) sbp Rallye wheels with 245/60R15s (with room for 255/60R15s (next time)).
I am getting close to ordering these ones too. Even though they are drag spring I’m wondering how you find the ride?
Could you pretty please post some good pictures of your car from the side? I’m thinking this is looking hood and just what I want. I’ve seen the 3200 pounders on your car (darts) and they definately seem to sit higher that this picture here.
As others have said, there no point extending the life of those springs by re-arching them. Toss them in the recycle pile and buy a new pair. New steel that hasn’t already spent 45+yrs holding up over 1,200lbs and flexing/bending while covering well over 100,000 miles.
what are you looking for in a spring? you drag racing a bunch? then yea go with the SS springs.. if its mostly street and you just want the height then go espo or eaton and get +1 or +2 inch springs..
I can't imagine that this is accurate. Perhaps they said do not overtorque the shackles or not to torque the shackles until you put the weight of the car on the wheels...
Exact words from Laura at Espo:
The Mopar books seem to list a torque spec for shackles but shackles are shoulder bolts with lock nuts and shouldn't be torqued. They should just be tightened until the side plate is seated against the shoulder of the bolt. There's not enough space to torque since torquing is stretching and it's only the thickness of the side plate between the shoulder bolt and the nut that would stretch. I started writing that on the invoices after seeing crazy torque specs in Mopar service manuals and people were breaking shackle bolts.
She's a smart gal. Espo is a great company. Re-arcing springs is just a band-aid fix.
I still like the S/S springs. My car has had the on for 16 years and still rides good. I did drag race this car alot. I still drive it alot on the street. The stance is right if you set the front torsion bars right.
I just have to laugh,This post started just about 8 months ago and the one who started it no longer owns the car! Better yet he did not even put new springs on it after all the advice and opinions you guys gave.I bought it in November, still waiting for nj title so I can get registered. I just want to thank everyone on this form for your advice and guidance in advance. I did just order new springs from espo springs and things (6 +1") ,can't wait to get them on the car
