I need a hydraulic clutch
Dne007
Cypress, Tx
Hi, I'm dne' for those of you that don't know me, :lol:
I'm thinking I want to go ahead an install my Super Six into my '63 Dart, I just need a hydraulic clutch, well and pressure plate/clutch plate.
I know about Brewers, just looking at other options. I even wrote Red Roberts at Driveline performance as I helped them design the clutch system adapter for a 67 Mustang with a power booster, still waiting to hear back.
:thankyou: dne' ;)
Then this is on ebay:
My 67 Mustang with hydraulic clutch
I made this piece of plywood and sent it to Red Roberts at Driveline components, then they made it out of metal and sent it back to me for test fitting;)
Don't know if it will help, but the Ford Bronco IIs had a hydraulic clutch. Like 1985...
Might be able to hit Rock Auto and get the slave cylinder that mounts to the bell housing. Offroad outfits have pedal sets with Hydraulic Clutch Setups...
Much like Brewers, there is also Passon Peformance that specialize in Mopar manual transmissions.
He also carries the retro and all the parts for conversions.
I did allot with Jamie Passion in the early to mid 2000's. Nice and easy to work with. My 2 cents.
1985 Bronco II V6
Clutch Master Cylinder
1985 Bronco II Clutch Slave Cylinder
They also have the Bronco II Pressure Plate, not much money and you may be able to redrill your Slant 6 flywheel and bolt it up. Might have to special size the Slanty clutch disc to fit the pressure plate. But by the looks of it, no problem for you.
here's the easy button:
obviously a big fist full of doubloons.
but you could reverse engineer it, which you've already figured out with the mustang you did. the key is just sorting out the throwout and then configuring the rest around it-- getting the right contour of the throwout face for whatever clutch you're running (obviously a concern with the early body stuff), the geometry/linkage & throw to the slave cylinder, the lines are a secondary concern, really.
the kicker is figuring out an inexpensive throwout-- i've heard everything from 90's nissan pathfinder, ranger V6, viper, 80's camaro; some direct install some requiring any sort of machine work to either enlarge the ID or on the mating face.
the only direct experience i have is with the mcleod throwout and a diaphram style unit and the S10 master on a later A so it's not exactly an apples to apples comparo. also, race car so not exactly a "clean" install.
that looks great you dont have trouble bleading it at that angle
bronco/rangers are hard to bleed would think an external slave would be easier to fab and bleed like my 67 dodge p/u
I’d probably be ok with a manual clutch, I shouldn’t have said need, just like to install the engine/trans together, thus I Want some sort of clutch. Guess I could put out a ad for the parts for the manual system.
It’s easy to get caught up in the hype of things. Oh you’ve got to have a hydraulic clutch, when in fact people seem to have gotten along fine with a manual system. Crazy isn’t it :lol:
The simpler the better...Less expense and less to maintain. Flip side the setup looks nice and is certainly easy on the left leg. With that slant the real estate in the engine compartment isn't nearly an issue... to where it looks crowded. The old automatic 65 performance package Barracuda Karrin and I have has the enhanced braking package. The blue Avatar car has the simple acorn master cylinder.
Ok, I guess a change of plans, "simpler is better" as Jeff said, so I could at least install the clutch plate/pressure plate, get a new throw out bearing, I have the fork thing and internal bell housing parts. At least I could get the engine/trans installed relatively soon. Just have to search for the other parts later. Ya'll just gonna have to put up with me :lol:
I agree. I went with hydraulic (mainly due to the hype) and I had geometry issues due to the slave hitting the inner fender, then I had lines leaking, it was a mess.
You should have a TO bearing with your new clutch, and if you have the fork, set that in place. You can install all of that in the engine and then mate up the trans. Install both and then just call Brewers or send him an email and he will give you a quote for anything missing. He's great to deal with.
I like your response :thankyou: , I'm just really excited to install my S6, just one big thing out of the way :thumbsup:
I am thinking back in the day, didn't Pinto's and Mavric's have cable operated clutches. Which worked well until the V-8 powered swaps caused some firewall issues, flexing. But I am sure that issue can be easily fixed.
When I bought my brake/clutch assembly, it didn't have spring. I've been searching for a decent diagram, only found one down below.
I just don't see how it all works! or where's there's room on the engine firewall side for linkages. or where the ball thing will mount onto the frame? questions questions
I found a seller on ebay, was just about to buy it, but I thought I'd better check with you guys. Just some things I'm not very good at.
I think I have the spring going to the wrong place?
