I need a hydraulic clutch
Yeah, I didn't really get anything from the last excursion~ I worked my butt off!
This is some pics I sent to him with measurments, I told him it be useless unless he can come up with a shorter clutch MC.
He would use 5/16 plate, last time he used my template and now is on ebay;)
That's really nice, so one eliminates the clutch pedal? obviously, have an install picture?
I don’t sorry but do a search here. There’s a handful of guys using them.
hm, got this in just now. It was a close out at rock auto for 47, with s/h 62 bucks, looks pretty good!
I may be wishy washy right now, but just discovering all kind of stuff. What I said up a couple links, it would be dumb not to go with this designed for an A833. Of course it may be dumb not to just go for the old school manual clutch system. I'm just shopping is all.
Red Roberts idea was for little to no drilling~ he wants an item to be installed as simply as possible. Sometimes it just doesn't work out that way.
This one, one just makes a hole, mounts the mc and there you have it!
There have been some problems with setups like the wilwood and the McLeod with A body firewalls and being able to get the correct angle, and pedal ratio when using them. Do some research before you order, everything I learned doing mine I found right here on fabo doing a search.
