When I search, I get lots of article on how to measure the car to get the ideal drive shaft length to order one. What I need to do is determine if the shaft i have is the one I need. The car in question came with and 8.75 from the factory, but had the rear end replaced long ago when the SG malfunctioned. It got a replacement "from the yard" as is a 7.25 rear. No one knows if the driveshaft was also swapped or if this is the original shaft and I know that the original driveshaft was 49.58 in. and was 2.75 dia. Questions is WHAT was 49.58 in.? Is that total length from yoke to yoke (X that I added in the drawing below), center to center (A in the drawing), or something else? I am putting an 8.75 back in and want to measure to see if this driveshaft works or if it was swapped out/cutdown, etc. I don't see any obvious evidence of shortening.
