My 241Your what?
My 241Your what?
The ones I bought for $200...............
You all read it here. Mike is going to strip and sell himself with 2-4-1 deals
Whew!
Thank God the page flipped.
It took me a min. to figure that out.
What was the pre-flip that made it "Good"?Whew!
I really need to strip and get photos of my parts.
I'm gonna pay for that.
We have the missing cold over hereMother Nature has decided to skip Spring Wind and June Gloom. It's July! Git the fireworks ready. Close to 80° and hardly a breeze.
That and wagon suspension, twist truck through a ditch one way, steering is off, or the other way and its back. If my truck would drift slightly right if i let go of wheel im fine with it. Its the crown in the road causing it. Cant make em perfect,crown, road condition(ruts) and wind are contributing factors to how they roll down the road.Most likely it is aligned. These trucks and ramchargers from that era are famous for the steering box issues causing the steering wheel to be off centered slightly when aligned correctly. Mostly due to wear in the steering box. You have three options: reset the splines at the box, or pull the wheel and set it straight level. Option 3: get a new box entirely.
I’ve done all three…
You're a good man Charlie BrownGot my airhose reel moved. Then i yoinked out the mustang so i could work on a friend’s wheelchair van. New to him, wife’s electric chair wouldnt go all the way in due to some apparatus on the floor. Then a little inspection under the van. The gas tank is shop built,and relocated. Rusting, not a good thing. I sprayed it with some rust check, hope to slow the progress. Im pretty sure no one in the area will do it for free.
Bought this a few years back at an auction I went to for 65 bucks it’s an old library index card cabinet I use it for my nuts and bolts etc it was a great buy
Yep. Have the same issue with my Jeep. Anything with a solid front axle is very susceptible to the crown of the road problems.That and wagon suspension, twist truck through a ditch one way, steering is off, or the other way and its back. If my truck would drift slightly right if i let go of wheel im fine with it. Its the crown in the road causing it. Cant make em perfect,crown, road condition(ruts) and wind are contributing factors to how they roll down the road.
Denis the MenaceI posted this in the general forums.
Jay North passed away.
Old heads here will remember him as Good Old Mr, Wilson's neighbor.
Lol! That comment is brilliant!You all read it here. Mike is going to strip and sell himself with 2-4-1 deals
Not lost but certainly needs a bit of TLC, ie more rock and gravel. It’s just money right?Gotcha....
I never did confirm if you lost your bridge?
