Can you tell us more about your cam, car, weight, et, mph, idle Rpm in gear, converter and gear?
Thanks
Ok, now that I’m on my iPad and not my phone and I can actually see what I’m typing I’ll try this again.
Cam: 281/281 255/255 .620/.620 105/105.
I’ll go back together with 155-160 on the seat and 355-360 on the seat.
1973 Dart Sport
3550 with my fat *** in it.
No ET or MPH with that iteration. I bent 3 valves because I screwed up so I pulled it down to check everything. I finally got the cam back today. Three lobes looked wonky. Hey were only down a few thou but they just looked funny so I sent it back to Racer Brown for a regrind.
950-1000 rpm idle but it will easily go down to 750. I don’t let anything idle that slow. It’s a stick so that’s the idle speed.
It was 11.55 or 11.75 compression, I forgot. Now it’s 12.2x on pump gas.
The pistons have been coated with Line2Line abradable coating.
3.09 first gear non OD gear box, 4.56 gear and a 26 inch tire. That was with the 8.75. I have a D60 now with 4.88’s and a 28 inch tall tire.
It had a fully ported Holley Strip Dominator with one 830. Now it will have a Weiand tunnel ram with two 830’s.
It had Hooker 5204 headers. 1.75 x 3 inch. Now it has Hooker 5303 headers which are 1.875 x 3.5 inch.
I had a Mallory Hyfire VI with a 29440 coil.
Now it has a Mallory Hyfire VII with a 28880 coil.
I had a Carter high volume mechanical fuel pump with 3/8 line.
Now I have a Mallory 250 GPH electric fuel pump with 5/8 line to the 4 port return regulator and 5/8 return.
McLeod Soft Lock clutch and 12 pound flywheel.
The gear box has a standard first gear, a pro shifted second gear and third and forth are slick shifted with synchros.
I had a Hurst Super Shifter III. Now I have a Hurst Ram Rod which is an inline shifter but not a vertigate.
I also upgraded to a dual range tach.
Milodon Super Stock pan with static pick up.
Iron heads I ported (going on the flow bench this Sunday) with 50 degree seats.
I use exclusively Torco engine assembly and cam lube.
I’ll break the engine in with Torco 30 break in oil. After the cam is in, I’ll spend the 40-60 minutes to break in the pistons, which should run at about .0015 clearance.
After some power pulls for data, the engine will come back off the dyno, I’ll pull the pan, install the crank scraper and windage tray, bolt it back to the pump and the make some power pulls to see what the scraper and tray make for power. Or save power which is more correct.
After that, I’ll spend the hour or more to dial in what the engine wants for a timing curve. Then I’ll spend possibly two or more hours to make the distributor have the curve the engine wants.
When all that is done I’ll make some power pulls to verify the timing curve is actually what the engine wants. If not, I’ll have to spend more time figuring out why the engine isn’t happy.
If it is happy I’ll change the break in oil out for Torco SR-5r Ow20 oil.
At that point I’ll start doing the rest of the tune up including lash loops, some more work on the timing curve.
When I’m happy with that, I’ll work on tuning the headers by adjusting primary and secondary tube lengths.
That’s all I can think of for now.
