WAYNE0
Who out there has relocated the battery to the trunk ? What size positive wire going to the starter did you use ? How did you route the wire going to the stater ?
I have a paxton supercharger. I need the space to put the catch cans from the valve cover breathers. Plus i want to move the horns to that area because i am going to put the supercharger air filter through the rad. support where the horns are.Why do you want to do this?
Different reasons might require different safety devices
Same here except I used 1/0 welding cable due to its flexibility. And this cable is dead except during crank as I use a "Ford" relay in the trunk by the battery to only energize it when I crank the engine. This prevents any future chafing/rubthrough concerns as a short would be pretty evident if it only occurred during crank.0/1 gauge cable: Trunk => into pocket between body and interior panels => into door scuff plate wiring channel after some persuasion => under carpet => through new grommeted hole in firewall to starter.
www.forabodiesonly.com
