QWKSLVR
We are working on my brothers 73 Duster. Original was 2 speed motor and switch and we just changed to a 3 speed motor and switch. Also changed the short arm that bolts to the motor along with the long arm that snaps on to the short one. Both arms are supposed to be correct for the 3 speed system. All three speeds work. Problem is when you turn off the switch the wipers park in the up position. I was reading through previous posts about park issues and some people mentioned checking grounds. The motor does park just in the wrong position, could it still be the ground. Thanks for any and all replies and help.
Bobby
Bobby
