dibbons
The cylinder head and main cap bolts are easy enough to identify. Now going through the rest of 'em to find what's missing. Main concern is the correct camshaft bolt and the oil pump bolts. Some will be re-used others will be replaced. These come from a "complete" 340 core motor I purchased in Sacramento some years ago.
Photo #1: cam thrust plate (four-one with hole), two unknown; #2 one dist. hold-down, two possibly fuel pump (integral washers), five unknown (loose washers); #3 ten rocker shaft, ten exhaust manifold, four large unknown, three small unknown, three misc unknown (short, medium, long); #4 twelve intake manifold (one shorter than the others); #5 twelve oil pan, four unknown (smaller w/washers); #6 nine-probably valve covers (two shorter than the others); two unknown long bolts (with washers); #7 various water pump/timing cover-two very long, six long, 4 short, 4 very short.
