DionR
The openings in the frame are within 1/16” of each other in the car. Right side is 9 1/2”, the left is 9 7/16”.
When Rich installed the right UCA, it fit right in with a little persuasion. The left side though… the overall width of the arm was a strong 1/8” bit not quite a quarter wider than the car. Not ideal but given that the car itself measured 1/16” narrower there, I just milled the aluminum spacers and moved on.
Ah. Base on that, it sounds like the arm was maybe only 1/16" or a bit more too wide. I would have smacked the mount with a rubber mallet a bit and I bet it would have slid in. That's what I had to do to get the SPC 1.0 arms installed last week. Didn't take much persuasion in my case, but this is the arm that has the thread legs so it was just the width between each ear that was an issue.
I wouldn't say the arm was mis-fabbed in that case.
Now the barrel not being in plane so the adjuster works is a different matter.
