What I find interesting about this build is not the turbo part of the build but the NA @ 13:00 mins.
When they add TF 240 heads to a stock low cr ( low 7's cr) 440 with questionable ring seal and only a xe268h cam now the motor is making ok power obviously not super great especially for the heads. 433 hp @ 5300 rpm & 474 tq @ 4300 rpm not bad for a low 7 cr xe268h cammed engine obviously the heads are doing most the work but if you up the cr to something more reasonable power probably be up another 30-50 hp add a roller 224 cam and probably be in the 500's hp.
I just found what the xe268h did with this engine to be mildly impressive.
