Fuel Gauge not working
No, I have not. That's the can of worms I'm hoping not to get into. I had the dash out to change out all my bulbs and that was Nightmare IMHO. Had to drop the wheel to free up some space. Wiring was very Taut and I actually cracked a cornere of where it wraps around the column. It glued together really well without anything noticeable but I don't want to have to do that again if I can help it.
I changed the bulbs by Braille, I just stick an arm up underneath while laying on my back across the sill plate and driver's floor and feel for them. They unscrew and then you pull the bulb out and change it but I'm sure you know that
Replaced my fuel sender with aftermarket way back. About 4 years later it failed. Removed it to find a tiny crack in the brass float. The brass gets thin where a groove is formed in it. China brass too thin. I compared cost of new float and seal to the cost of entire new sender, a no brainer.
I tried that for a bit but could not get them all. At 69 years old I'm just not a contortionist anymore. LMAO
