Stop in for a cup of coffee
Probably only needs cleaning and lubrication, great TT with 7 lb platter, holy cow!
I have an Onkyo turntable that I bought in the '80s. Hasn't seen a record in probably 25 or 30 years. LOL
I know the pin striping on the dash matches the stripes on the truck. I'll look this evening and see if there's a tag under the hood and get some more pictures. The truck seems very original.
I had a dodge short bed truck with all the pinstriping but it was not a Warlock This doen't make it a Warlock. You have to use the numbers on VIN tag.
Well on the core. VIN I don’t think tells us if it was a warlock package though it’s been a bit since I’ve looked
So as I explained a few days ago I have been rearranging book shelves to accommodate the new mini split. One of said shelves is a hand made 12 ft by 8 ft Monster out of solid wood. She is heavy, I made it male and female so the top half can lift off but it takes three to four healthy lads. I built it custom to fit in a specific spot thinking I would never move again! Hah! So anyway it is heavy! My solution is pictured below!
Ford guy: Would cry and whine to his boyfriend then hire movers to do it.
Chevy guy: Would buy pizza and beer and invite a bunch of bunch of his buddies over and trick them into moving it for him.
Mopar guy: Scabbed a side board piece on end of shelf, put bottle jack underneath, then slid cut to fit closet rod under the case, then simply pushed the case with one hand down the wall to new location.
Problem Solved!
Problem Solved!
That's how they built the pyramids
Problem Solved!
Genius
