about a month and a halfI went on and sent them a cam very recently. How long did it take you to get yours done?
Well its been a long time coming.
Finally got the car running. Im pretty bummed out. Sounds about exactly the same as it did with the stock cam.
No noticable idle chop at all.
Back to the drawing board :/
i guess my issue is, i had this exact same motor setup with an inferior (on paper) lunati cam and the performance and sound are were absolutely night and day. The 360 magnum with that lunati cam sounded like a freight train and pulled like absolute hell. That car scared me for a while at first, and this same combo with what should be (on paper) a better cam, just feels like the stock cam. switching from stock exhaust to flowmasters felt like it made more of a difference than this cam did. I'm pretty baffled by it. Almost made me wonder at first if i wasn't accidentally sent an unground bone stock core or if id accidentally reinstalled the bone stock cam. the difference is that negligible.Just keep in mind, the engine is a package of parts that work together. You don't simply change "one thing" and expect a huge impact. If the engine was stock before and all you changed was the camshaft, any changes in power production will likely be minimal. Also as the camshaft gets "bigger" with more duration, more overlap and a later intake closing event, the engine will get more sluggish unless you change other variables such as air flow and compression ratio to match the different camshaft. All the parts must match the intended purpose, or you can likely end up with more of a slug.
I built a stock bore and stroke Ford 5.0 awhile back with that same cam (your Oregon) and it has a pretty lumpy idle. Much moreso than just the cubic inch difference. It ended up going in a little square body Ranger a friend of mine's son has. She told me it will smoke both back tires pretty much as long as her son has his foot on the gas. I think @TrailBeast has that same cam in a 360 in his Dart. Maybe he'll chime in.i guess my issue is, i had this exact same motor setup with an inferior (on paper) lunati cam and the performance and sound are were absolutely night and day. The 360 magnum with that lunati cam sounded like a freight train and pulled like absolute hell. That car scared me for a while at first, and this same combo with what should be (on paper) a better cam, just feels like the stock cam. switching from stock exhaust to flowmasters felt like it made more of a difference than this cam did. I'm pretty baffled by it. Almost made me wonder at first if i wasn't accidentally sent an unground bone stock core or if id accidentally reinstalled the bone stock cam. the difference is that negligible.
Oregon 1341: 218/224 @ .050”, 270/276 adv, .482”/.482” lift, 110 sep
Lunati: 220/220 @ .050, 280/280 adv. .442"/.442" lift, 112 sep
that's really making me wonder if i wasn't accidentally sent a bone stock core that wasn't ground at all.I built a stock bore and stroke Ford 5.0 awhile back with that same cam (your Oregon) and it has a pretty lumpy idle. Much moreso than just the cubic inch difference. It ended up going in a little square body Ranger a friend of mine's son has. She told me it will smoke both back tires pretty much as long as her son has his foot on the gas. I think @TrailBeast has that same cam in a 360 in his Dart. Maybe he'll chime in.
You can measure the lift and find out. I guess you didn't put a degree wheel on it?that's really making me wonder if i wasn't accidentally sent a bone stock core that wasn't ground at all.
Is there is a chassis dyno near you that can tune, check air fuel ratio and do a timing sweep on your combination to make sure you don't have something holding it back?no, just lined up the dots.
This should be a lesson, then.no, just lined up the dots.
I don't know what they charge where he is, but the cheapest one around here is around $500 an hour.Is there is a chassis dyno near you that can tune, check air fuel ratio and do a timing sweep on your combination to make sure you don't have something holding it back?
Yep, sure sounds like it was installed retarded. That would account for the piggish off-the-line performance.You can measure the lift and find out. I guess you didn't put a degree wheel on it?
how can it be installed retarded when the dots are perfectly alligned, that should be perfectly centered, one way or the other would be advance/retardYep, sure sounds like it was installed retarded. That would account for the piggish off-the-line performance.
$500 would would get timing swept and carb jetted (holley) on my dyno. Sounds like I'm too cheap.I don't know what they charge where he is, but the cheapest one around here is around $500 an hour.
What is your dynamic compression(?) and manifold vacuum. Ken knows what he's doing, he may not have given you a cam larger than your combination, compression/valve spring/drivetrain warranted.Test drove the car today, still pretty darn underwhelmed. Itl break the tires loose if you tromp it from a dead stop, but with a 2500 stall and 3.73 gears i would sure hope so.
But not all that much better than it did before with the stock cam.
I guess everyones idea of hauling *** and making power isnt the same. On paper this should have put my old dart to shame.
Gonna pull the motor this winter and try something else combo wise. Maybe heads or pistons, On the plus side i learned a lot doing the swap by myself for the first time and i have good solid data to proceed with.
I dont think anyone gets it right the very first try. Our cars are never "Done" , right?
On to the next chapter.
This is the whole point and reason for degreeing camshafts. Because there is zero guarantee that the timing sets and the camshafts are made so that when everything is assembled, the camshaft is in the right place. Since we are measuring in DEGREES, that means a very small difference can add up to a large tolerance stack. If the cam sprocket is off one degree, that's two degrees at the crank. If the crank sprocket is off by another degree, there's one more. That's not even counting on Chrysler having machined the crank keyway in the exact right place, OR of the cam company machined the cam just right. This is why it is absolutely imperative that you degree the camshaft. But no matter how much we preach it, there are always some who will always refuse to listen and will never get it.how can it be installed retarded when the dots are perfectly alligned, that should be perfectly centered, one way or the other would be advance/retard
