SRT_DSTRHOLC
"There is never enough horsepower...."
Does anybody have a measurement or a point of reference they use when lining up the tail shaft of the transmission to make sure the play in the u joint is where it's supposeed to be and the angle of the driveshaft is set to the pinion on the center housing of the rear?
I have some play from left to right when mounting the transmission to the X member and being that the X member is aftermarket the hole has been slotted, so looking to keep the angle from binding.
