Anyone Running 215/70-15 tire on the front of a Duster?
I want to run this size on my Duster. Will they hit
73 duster with large boltHey Dave- small bolt pattern or 73 and up large bolt pattern?
Turn the wheel a few degrees clockwise where the outer edge of the tire is aligned with the fender lip.Looks like I have room for 215/70-15
Mine has Bfgs 215/70/15's on the front. Rub on passenger side when backing and turning at full lock. Drivers side perfectly fine but passenger on full lock reverse is iffy. I raised the torsion bars which helped and still small slight rub. Going to 215/65/15's next tire change for fronts. Suppose to be perfect size i have gathered with zero issues and i think would be perfect.Anyone Running 215/70-15 tire on the front of a Duster?
