Anyone got a ford?
diymirage
HP@idle > hondaHP@redline
michigan
Cheap beat up '06 f250, white regular cab long bed
I'd like to use it as a keychain for my work truck
1:64 of course
Rural king has 350 crew cabs as well as 3500 Ram crew cabs.
Not sure the year but fairly late model.
Quite the opposite ...I'm hung like a racehorse and I simply do not have enough room in my pants for anyting larger then a 1:64
I'm hung like a can of tuna and when I get done there's room to park a 1:18 in there, but only the front clip.
I figured I could make statements like this because come on, no one is gonna check
On a side note, I just ordered a 12 pack of 1/64 Forest to make a key chain out of, the other 11 will just go to the church kids
And ....I m looking again
Turns out '12 pack' is the pack they pick one out of and ship it to you...liars
Reminds me when still at home before graduation (1971). I was driving a '56 Dodge Custom Royal, with a 315 WCFB and 3 speed on column, with dealer installed duals. Anyway, it was running rough, so I had the hood up a checking everything out. Neighbors across the street were Ford people. Bobby, the son sitting on the swing yells over "should got a Ford." So back in house I go. I come back and take the big oil bath air cleaner off and yell for Bobby to come over. When he gets there, I said "I found the problem. The car will run better now. You said I should get a Ford; I did." I had a small magnet with a Hot Wheels mustang on the other end and pulled it out of the WCFB. I looked a Bobby and said, "told you this thing sucks up anything in its way."
