360, idles great stumbles uptop
zano
Member
Swift Current, SK
Howdy, i have a 1976 d100 swap with a 79 360 bored .030 over just swapped from 2 barrel to a 4 barrel intake off of a mid 80's? 360 have a 670 holley street avenger with long tube headers. The issue I'm having is it idles great and runs mostly okay up to about 3000 rpm the start spitting back through the carburetor and it doesnt seem to matter where I set the timing and the vacume gauge seems happy and it starts nice right now. Debating on if I need to rebuild the carburetor not sure if its getting to lean uptop.i got the carb second hand I did set the carb back to factory settings and didn't seem to help much, its pretty clean for the most part inside. So not sure what the plan of action should be next
Disconnect the vacuum advance and see what happens. If its mopar electronic ign. you may want to switch the box out or check the ground on the box itself,
I have deleted all the factory mopar it is running on an hei distributor now. Even after switching it runs the exactly same basically
Float level seemed okay it was just coming out of the sight holes, which is where it says to set it. I can set it to advance a bit more if need be but it was the same for 3 factory distributors /vac advance. My thought is could it be gaskets failing in the carb or something? Maybe letting air in or something
'79 360 flat tappet cam engine.
Is that the original cam and lifters yet?
Original heads... kind of sounds like valve float. Original weak, lost tension valve springs. Cams start to wear rounding the peaks off not fully opening the valves at rpm.
Take a heat temp gun and check header exhaust temp at the head exhaust ports. Should be 400° or so.
If running cooler, probably needs more fuel.
It may or may not be original it was rebuilt at somepoint. That could be a possibility though. The cam definitely has some miles on it but it looked okay when I changed the intake, but could definitely be weak springs or wore lobe, I just find it weird that it always ran really good with the 2 barrel and could go through the entire Rev range. And it only happend after putting the 4 barrel on
Try another known good working 4 barrel (from a friend).
Process of Elimination
Carbs sit around and clog up real easy.
Or take your carb and put on a known good running engine and see if that engine acts up.
That's what I use my "Test Run Engine" for.
Haven't had a chance to do it yet, picked up a car this weekend to toodle around in. Got some gaskets and a powervalve to pull the carb apart probably do that tomorrow. Needed a small break after all the work on it lol
Here are some of my guesses;
1) maybe it's just a Secondary tip-in bog, cuz the secondaries are coming in way too fast. Try disconnecting the Secondaries and wiring them closed.
) a muffler is severely restricted. or
3) somebody left a rag in the intake, or
4) check your EGR system. With headers, it should be defeated.
5) I woulda said cam-timing, but you said it ran fine on the old 2bbl. but I would still check it cuz it's so easy if yur not looking for exact cam timing. I would just check to see where split overlap is occurring.
6) if it had started at a lower rpm, like 2000/2500, I woulda said to check yur rotor-phasing as the VA starts dropping out.
7) if you woulda said seems to be related to the throttle-opening at lower revs, I woulda said, check the pick up connections.
8 if you had said the timing light goes crazy as the revs pick up, I woulda said, reverse the pick-up polarity.
Good luck
Howdy, so had some time today, rebuilt the carb, put a spare power valve in it, and put 68 primary jets with 76 secondary as it has a 65primary and 68 secondary, found some gouges in the metering plate but nothing that should effect it. Ran it again and it ran the same.
Might be onto something with that i guess it starts right around 2000 rpm. The egr system is deleted, has virtually new exhaust on it so that shouldnt be an issue. Will be posting a video on YouTube
If it is rhythmic, might be a cam going flat
Time for a compression check. Burnt Valve or Stuck Valve, or bent push rod not opening valve far enough.
Read the spark plugs, are they all burning the same, or is there one or two odd balls?
so what I'm hearing is time for an ls swap lol, i have nothing invested really into the drive train of this thing, so really on the fence if it would be worth touching it since it is an la engine and price to performance isn't great and I'm not super concerned about purity. its a shame cause it ran good, but at the end of the day is it do i just swap it to something else, could just sell the carb. and headers and get the swap. time to ponder anyways. truck need to come back for next year i miss driving it lol.
