66 Cuda Power steering gearbox swap
MechNerd
I can fix stupid, but it's gonna hurt...
MI
Original ps gearbox had a 1/4+ turn of play, so I replaced it with a stock replacement. When I picked it up, I eye balled one against the other, and I thought they matched. As it turned out, sector shafts were different diameters. Close, but the new one was slightly bigger. Didn't realize it until I tried to install the pitman arm.
Long story short, I've read all the posts regarding this issue, (looks pretty common), but no info on matching pitman arm. Anyone have the correct part # for the pitman arm for the larger sector shaft?
Firmfeel Mopar Suspension and Steering
I hadn't heard of one either, but, it could be made if someone really wanted to.
