Woring on my '68 Dart 340 (with a '73 Duster K-member and suspension).
I took the t-bar out while I fitted the exhaust pipe into place. Now, trying to re-install the t-bar, and I can't get it to line up.
The UCA bumper is removed, the LCA adjustment bolt is fully loosened, the strut rod is not torqued, the car is lifted on the frame rails....in short, everything is hanging as low down as it will go. UCA is about 1/4" from hitting the bracket on the frame rail.
Still, I am just a smidgen off from being able to slide the t-bar in. See photos.
This is on driver side.
This is especially frustrating because the thing was in place before I removed it to do the exhaust pipe. So, I don't know what could have changed. It was very tight and difficult to get out, even though the car hasn't been driven since the t-bar was installed. Maybe that suggests that it was in a bind already; I don't know. But, I don't remember it being that hard to install the first time.
I'm sure somebody on here can explain to me what a dumbass I am and what I'm doing wrong. I'll take it!!!
