I had a driveshaft made and with it fully pushed into the 727 it barely fit into the differential saddle. I know the shaft is too long. How much room should there be between the yoke fully pushed into the trans and the rear U-joint saddle?
I put the yoke bottomed out in the transmission and slide it out .75" - 1". Then measure between u-joint centers (front and rear). That's the shaft length you want. I've bought my last four from a local driveline shop. The last one I got was 3" x .083 DOM tube and was right at $250 w/ new ends and spicer u-joints.how did you measure for it? and where did you get it?
If U-joints included, that`s a steal for these days, especially Cali.I put the yoke bottomed out in the transmission and slide it out .75" - 1". Then measure between u-joint centers (front and rear). That's the shaft length you want. I've bought my last four from a local driveline shop. The last one I got was 3" x .083 DOM tube and was right at $250 w/ new ends and spicer u-joints.
with the suspenion loaded.they measure from the face of the yoke to the end of the output shaft.and also the depth of the spline.I put the yoke bottomed out in the transmission and slide it out .75" - 1". Then measure between u-joint centers (front and rear). That's the shaft length you want. I've bought my last four from a local driveline shop. The last one I got was 3" x .083 DOM tube and was right at $250 w/ new ends and spicer u-joints.
My shop measures with the suspension loaded too, stationary. End of the output shaft to the flat of the yokedennys,empire,ect,dont measure that way
Plenty of ways to skin a cat for sure. I think if you have the yoke you want to use, measuring center to center of the u-joint is good. If you don't then the mail order places do the math for ya. Not a big deal either way.dennys,empire,ect,dont measure that way
Shop here wanted $100 just to balance check a shaft. I'd rather put that towards a brand new one.If U-joints included, that`s a steal for these days, especially Cali.
I shortened a shaft- custom length for the old Dodge I built, hoping to luck out. It talked to me above 60-65 mph, so I finally got it balanced, plus straightened for a little less than that. Soooo nice to get above 70 without cringingShop here wanted $100 just to balance check a shaft. I'd rather put that towards a brand new one.
Sounds like you did a pretty dang good job. Mine gets fussy more like half that speedI shortened a shaft- custom length for the old Dodge I built, hoping to luck out. It talked to me above 60-65 mph, so I finally got it balanced, plus straightened for a little less than that. Soooo nice to get above 70 without cringing![]()
thats a real bargainI put the yoke bottomed out in the transmission and slide it out .75" - 1". Then measure between u-joint centers (front and rear). That's the shaft length you want. I've bought my last four from a local driveline shop. The last one I got was 3" x .083 DOM tube and was right at $250 w/ new ends and spicer u-joints.
Measured from the end of the tailshaft to the flat on the diff yoke (edit: with tires on the ground). Took the shaft back to the driveshaft place today so they could cut about 1/2" off. When the rear u-joint is in the saddle, the front yoke is only about 1/4" away from bottoming out. Not sure if I mismeasured or if the driveshaft place did. No biggie, they'll fix it. Thanks for all the replies.how did you measure for it? and where did you get it?
^^^ this.It doesn’t matter how you measure. As long as you measure exactly how the the guy that is building the driveshaft asks you to measure. Just like pushrods. But you need more slip than basically zero for suspension movement or you’ll junk the trans.
Agree completely. I asked them how they wanted me to measure then I provided those measurements. Did that directly to the owner through a phone call, though don't know if he was the one to make the shaft... doubt it. Possibly something was lost in the translation.^^^ this.
this. and i cannot stress is enough: ask them how they want it measured. and then be specific with who you're talking to.
i had a driveline place that one guy would want them measured one way, and the other would want them a completely different way.
Could be. PST, when talking with them, needed to know the manufacturer of the yokes, then had me send him the front yoke so that had it and installed it right away.Agree completely. I asked them how they wanted me to measure then I provided those measurements. Did that directly to the owner through a phone call, though don't know if he was the one to make the shaft... doubt it. Possibly something was lost in the translation.
This local shop has been doing driveshafts for many decades & I've never had an issue until now. The owner is very knowledgeable and I've used them for many car projects. They supplied the front & rear parts of the driveshaft too.Could be. PST, when talking with them, needed to know the manufacturer of the yokes, then had me send him the front yoke so that had it and installed it right away.
