Turk,
Of course when you start losing the argument, you start LYING. I
never said Carter elec pumps make 'zero noise' [ post #51 ]. They make less noise than Holley rotary vane pumps because the motor is enclosed in fuel which dampens the noise. The C pumps came out in 1969, muuuuuuuuuuuuuuuuuch earlier than Mallory pumps hit the market. So there will be thousands of them out there. Another reason why there are more C pumps out there is because they are so cheap. The design [ below ] allows for a cheap but effective pump. Of course there will be failures, & any idiot can go on the web & find some. I thought you would be better than that....
The 1000 hp pump, Carter #4601, 16-18 psi requires a reg. I use this on a couple of cars.
Mine has been on about 20 yrs, driven weekly. For the fuel filter, I use a spin on filter from a small diesel truck, looks like a small oil filter. 1/2" pick up line to the pump, 1/2" line to the filter. [ this pump comes with
1/2" line fittings ]. All mounted near the tank. The pump is mounted behind the driver's rear wheel which shields the noise.
I cannot hear the pump when the engine is running. This layout will depend on the car, chassis etc. I have a 3/8" rubber line from the filter to the reg, which is on the f'wall. I timed the fuel flow into a container & the rate was 90 gph. With the AFR correct for non-E fuel, that would support about 1080 hp.
